Laminate flooring pattern to use
Hi, new here so hello to you all, i've just started laying my new laminate, but not cut one piece yet, just ran into a problems, two pictures here, you can see the way the laminate is laid and when i go to lay the third row it doesn't match the first two rows, and the joins will be out if try to make it match, any ideas how to lay this with similar joins all over without wasting loads of flooring, thanks for any help really appreciate it.
