Roger440 Posted November 2, 2024 Posted November 2, 2024 11 hours ago, Russdl said: But what about the entrance to the garage? My slab is ‘thermally broken’ with a GRP box section and the easiest way that was going to work (in my head) was the foam glass route. Because im an idiot, i miscaluclated where the door would land, mainly because i changed my door solution post slab laying, but if we ignore that aspect, i put 2 inch EPS on the upstand where the door was, then cut it back at an angle so the block paving could run up to the concrete. So yes, something of a thermal bridge there. Could have put a thin sheet of something in the gap to actually break the bridge though.. Like a thinner GRP box section. Perfect, no, but light years ahead of any other garage i have had. 1
Gow Posted November 15, 2024 Posted November 15, 2024 On 27/10/2024 at 10:05, Russdl said: You’ll find him here:@Gus Potter and if you’re looking for a Structural Engineer/Architectural Designer I would heartily recommend you get in touch 👍🏻 I second that!
Gus Potter Posted November 17, 2024 Posted November 17, 2024 On 15/11/2024 at 23:33, Gow said: I second that! Thank you, much appreciated. Gus 1
