2 hours ago, ETC said:
Read the BBA Certificate for the underlay. It will say if you need roof ventilation and under what circumstances you can omit eaves and or ridge ventilation. Some underlays can be installed without roof ventilation subject to a well sealed ceiling being installed.
On reflection I think Tyvec might be one of those that do allow an unvented roof but I think down lighters are not allowed. Check it out.
Noted re the BBA cert, have started that process.
The few downlighters would be in the bathrooms, and we could have a boarded service void just in those rooms which would reduce the number of penetrations.
10 hours ago, Iceverge said:
A quick sketch. Couple of things.
I'Ve assumed a 35 deg roof pitch.
PIR in the walls......................between timbers........................groan..............Anyhou.
Here's a sketch of my idea.  A fink truss with extended 300mm tails to allow for increased ceiling height. image.thumb.png.6fbdc26a07cf3b899db4d5669c2d5e68.png
I was braced for the grimace re PIR in the frame!  I do note your concerns….  and I will price up blown cellulose for the loft…..   however as for the ceilings…..
I think I’ve understood, so I’ve drawn up what will be our version.
I know we could easily raise the ceiling more, but I hate chamfered rooms.
I did briefly consider raising the tie enough to accommodate everything, wires and ducts.  But it feels like more work and materials thus more time and money than plasterboarding straight onto the bottom chord of the trusses.
PS we’ve a 40degree roof.  And yes, we know that we could achieve the same headroom improvement much cheaper and easier by going to 39degrees…
How high is your ceilings as is?
The "feel" of the height of a ceiling is more important than the actual height.
Mathematically I think it's the ratio between wall length and ceiling height. A 2.4m ceiling in a 5m room will feel lower than a 3m wall. Vertical divisions like doors and windows on the long wall will make the ceiling "feel" higher.
This will "raise the ceiling"
This will "lower the ceiling
This will make everyone sick.
Don't do this.
Who ever is installing the plasterboard will tear the membrane.
Use 70*20mm strapping to make a service cavity below. It might enable you to push the trusses to 600cc too rather than the standard 400mm needed for 12.5mm plasterboard
If you fit LED lighting in a ceiling, you need to make sure they can cool correctly.
The light fitting manufactures will show minimum clearances, but they are just that, minimum dimensions.
5 hours ago, Iceverge said:
Don't do this.
Plasterboard ceilings need to be supported on 400mm centres?  Good heavens, I’m so out of date.  I’m standing in my kitchen and both upstairs and downstairs ceilings are 12.5mm plasterboard straight onto 600 centres joists or trusses.  But then, this house was built a third of a century ago.  How times change.
1 hour ago, nod said:
I wouldn’t  omit either
You need that airflow
Goodness, I’m so confused.  What are the things you wouldn’t omit?
And by airflow do you mean in the loft?
Eaves and ridge ventilation
I'm happy to stand my ground on having a sealed loft with no ventilation as per the tyvek detail.
I had it out with the roofers on this one and they all were shaking their heads but that was 4 1/2 years ago and no issue so far.
I was wondering @nod your thoughts though on plasterboard @400cc vs 600cc?
Bear in mind that trusses at 400mm centres would mean I’d have to attend slimming world like forever!    :-0
Just thinking through all this, and I can’t work out how the membranes would be done in practice.
Is there a way of sealing the lapped wall membrane to the roof membrane?   It could be just laid underneath it but I can’t see a way of that join being taped up.
  • 1 year later...
I thought I would resurrect this post as I'm faced with a very similar position as you and would be keen to know how it went. I have been researching methods to remove ventilation in our attic roof space (cold roof construction) during a major property renovation and came across this discussion. As we are installing EWI and taking lots of steps to improve U Values and air tightness, I believe the draughty attic is a weak link in our quest.
I have shared this "method" with my builder and he has responded with the same questions, especially the detail around the wall plate and how to airtight seal around all the trusses as we simply can't "wrap around" the Tyvek Supro.
Any further pointers appreciated.
  • 5 months later...
I think you're likely to have problems. You are essentially building a cold roof setup, which relies on ventilation to remove moisture from the roof. The moisture will get there, either from an imperfect vapour control layer installation (inevitable) above your ceiling. It will will naturally occur due to changes in the weather. For instance the roof might be perfectly happy on a warm day with 60% humidity inside the loft and outside. Then overnight the temperature drops and the loft gets cold, then condensation will occur in the loft just like due forms outside. Without ventilation, this could become an issue over time. No point taking the risk really, just ventilate it and no harm done. It won't affect the temperatures inside the house.
you wont pass building control inspection if your cold roof isnt correctly vented. The tyvec at ridge needs cutting out as it will  be overlapped with dry kit for the ridge. eggboxes at eaves where cavity insulation is covered by loft roll etc.
you can only get condensation if heat is escaping into the loft, 400mm min of loftroll everywhere and no probs.
Forget using loft as storage.
Crumbs, this post brings back memories.
We got sign off for a cold, unventilated roof, but we went for a ridge vent anyway.  Turns out just having a ridge vent gives ooodles of ventilation.
Making the roof truly airtight would have been impossible.   So our airtight layer is the VCL above the ceiling plasterboard.  Hopefully this will keep our steam out of the loft.
