jobe1972 Posted September 5, 2024 Share Posted September 5, 2024 Hi all new here and have no idea what I am doing so seeking help. I live in a housing association home which I am considering buying, but I need to build a shed at the bottom of the garden for storage wouldn't normally be a issue but as it was a new build in 2011 it had all of its permitted development rights removed all the houses did on the estate that were new all the old existing houses still have there's so I cant build a shed but my neighbour can and has .. So I am assuming I need planning permission the property did have a shed when I moved in but it was cheap and after a few years it collapsed .. seems so odd to me that the process of getting planning permission could cost more then a cheap shed . so any advice or guidance would be grateful for Link to comment Share on other sites More sharing options...
DevilDamo Posted September 6, 2024 Share Posted September 6, 2024 If Class E PD rights have been removed, then you will require Planning via a Householder application. Link to comment Share on other sites More sharing options...
Alan Ambrose Posted September 6, 2024 Share Posted September 6, 2024 I think if the old shed didn’t collapse in the last century, and the old one didn’t look crazy different to the new one … then you’re just ‘replacing the old one’, which is fine. I think I might just do this and see if anyone objects. If you’re in a conservation area, I might be a bit more circumspect. Link to comment Share on other sites More sharing options...
DevilDamo Posted September 6, 2024 Share Posted September 6, 2024 45 minutes ago, Alan Ambrose said: just ‘replacing the old one’, which is fine No it is not. A replacement building or structure is deemed as a new building or structure. Link to comment Share on other sites More sharing options...
mr rusty Posted September 7, 2024 Share Posted September 7, 2024 If we really are just talking about a garden shed, rather than an outbuilding, then even though technically not permitted, I would just do it. - What's a shed £1K? That's the limit of your risk, and personally I can't see any LA bothering to enforce against a shed if there was one there before. Of course, there's always a chance of a bad neighbour complaining, but if you get one of those, there are ways of hitting back, like suggesting you'll plant a row of tall trees if they are that bothered about seeing a shed. Link to comment Share on other sites More sharing options...
joe90 Posted September 7, 2024 Share Posted September 7, 2024 (edited) 34 minutes ago, mr rusty said: What evidence do you have of this original shed? At a previous house we had the same situation but no one complained when I put up a small shed. 34 minutes ago, mr rusty said: bothering to enforce against a shed if there was one there before. Edited September 7, 2024 by joe90 Link to comment Share on other sites More sharing options...
ProDave Posted September 7, 2024 Share Posted September 7, 2024 Check the planning history. You might find the existing shed has PP Link to comment Share on other sites More sharing options...
DevilDamo Posted September 7, 2024 Share Posted September 7, 2024 4 hours ago, mr rusty said: just talking about a garden shed, rather than an outbuilding A shed is an outbuilding, similarly to a greenhouse and detached pergolas which are both deemed as outbuildings. Link to comment Share on other sites More sharing options...
Alan Ambrose Posted September 7, 2024 Share Posted September 7, 2024 >>> the process of getting planning permission could cost more then a cheap shed The cost of householder PP is £258, so I'm thinking the OP is thinking of something not a million miles different from this: https://www.screwfix.com/p/shire-6-x-8-nominal-apex-overlap-timber-shed/644TJ Given this will last 5-10 years max, @DevilDamo are you suggesting the OP needs to apply for PP every time he wants to replace it? Even if it is identical to the last one? Link to comment Share on other sites More sharing options...
DevilDamo Posted September 7, 2024 Share Posted September 7, 2024 @Alan Ambrose PD rights were removed for a reason. The onerous is on the homeowner to check and apply for the necessary approvals. I would not advise anything but to follow the rules… unfortunately. Link to comment Share on other sites More sharing options...
