Just doing a check through our heating system at millstone manor, ready for winter, and have come across an odd problem. We have a radiator where the feed pipe is getting hot, there is no bypass pipe, but the radiator is not. I have had the rad off, checked it is not blocked and both valves are open, same problem. Feels like an air lock but the radiator bleeds fine. Any thoughts?
Is at the end of the system, could the radiators be balanced, so the flow is be gobbled up by the rest of the system. Enough flow to feel heat in the pipe but not enough to push through the radiator. Have you tried switching off a couple of other rads, to see if it improves things? That may tell you where you need to make changes
Not all valves are bi-directional. Check the valve to see if it has arrows going in both directions. Also, some radiators have flow diverters so will state which side the flow should be on. Check that too.
Assuming S or Y Plan - How close is that rad to the HW tank return to the boiler pipework? (is it just pipework stealing heat by convection?)
Is the rad fitted with a thermostatic radiator valve? Sometimes if they've been turned off the pin inside can stick down - you can try taking the control head off so you have see the pin position - with the head off the pin should be raised and you should be able to push it down. If it's stuck down, try (gently!) pulling with some pliers to free it.
Thanks all - I will get back to it at the weekend, draining it down and fitting a new 3 way valve as the current one seems to be letting by, which may explain where the flow is going when it should be going to the furthest rads, the TRV is the right way round its not stuck as I can push it down no problem so it must be an imbalance - has been working fine up until now - still best get it sorted before the winter comes.
