Stephen Goodey Posted July 12, 2024 Posted July 12, 2024 I wonder if I could ask for some advice? I am running a 2.5mm t&e from a socket in the hall along and through a wall into the garage up a wall into the loft space across and then to a consumer unit. As it goes through the wall in the garage I was going to put a conduit end box with rear outlet then a length of conduit up the garage wall to reach the loft space. I'm trying to figure all the bits I will need for the conduit. Obviously a length of conduit, galvanised as in garage?, end box with rear outlet, cover, saddles and clips. Any help appreciated. Steve.
ProDave Posted July 12, 2024 Posted July 12, 2024 If you start talking galvanised conduit, then you need a die and cutting compound to thread the ends. Never worth it for a one off job. Use PVC instead. I question the circuit design, it sounds like spurring from and existing socket to then feed a CU in the garage. The total load will be very limited, and a real chance of overloading the 2.5 t&e. A spur like that is allowed to feed one socket, that will be limited in current by the plug(s) plugged into it, not for feeding a CU for multiple circuits. Look to get a feed from the main house CU in proper sized cable for this.
Stephen Goodey Posted July 12, 2024 Author Posted July 12, 2024 Thanks for your reply. Sorry, didn't explain myself very well. It will be a socket being fed from the house main consumer unit. 2.5t&e will be OK for this? Steve.
BotusBuild Posted July 12, 2024 Posted July 12, 2024 Stephen, Is there a simpler way of just taking a spur from an existing socket? Or inserting the new socket in an existing ring ( this should be done by qualified electrician, but your suggested solution will also require qual. leccy as well)
joe90 Posted July 12, 2024 Posted July 12, 2024 1 hour ago, Stephen Goodey said: It will be a socket A single socket? Then that’s ok as a spur. As is a double socket I believe.
Stephen Goodey Posted July 13, 2024 Author Posted July 13, 2024 20 hours ago, BotusBuild said: Stephen, Is there a simpler way of just taking a spur from an existing socket? Or inserting the new socket in an existing ring ( this should be done by qualified electrician, but your suggested solution will also require qual. leccy as well) No, the way I'm thinking of doing it is the simplest. Thanks. Steve.
Stephen Goodey Posted July 13, 2024 Author Posted July 13, 2024 18 hours ago, joe90 said: A single socket? Then that’s ok as a spur. As is a double socket I believe. Thanks.
Stephen Goodey Posted July 13, 2024 Author Posted July 13, 2024 18 hours ago, Onoff said: Google "Appendix 15 of BS7671". Thanks.
Stephen Goodey Posted July 13, 2024 Author Posted July 13, 2024 Thanks for all your replies. I'll go with PVC. Steve.
