I wonder if I could ask for some advice?
I am running a 2.5mm t&e from a socket in the hall along and through a wall into the garage up a wall into the loft space across and then to a consumer unit.
As it goes through the wall in the garage I was going to put a conduit end box with rear outlet then a length of conduit up the garage wall to reach the loft space.
I'm trying to figure all the bits I will need for the conduit. Obviously a length of conduit, galvanised as in garage?, end box with rear outlet, cover, saddles and clips.
Any help appreciated.
Steve.
If you start talking galvanised conduit, then you need a die and cutting compound to thread the ends.  Never worth it for a one off job.  Use PVC instead.
I question the circuit design, it sounds like spurring from and existing socket to then feed a CU in the garage.  The total load will be very limited, and a real chance of overloading the 2.5 t&e.  A spur like that is allowed to feed one socket, that will be limited in current by the plug(s) plugged into it, not for feeding a CU for multiple circuits.
Look to get a feed from the main house CU in proper sized cable for this.
Thanks for your reply.
Sorry, didn't explain myself very well. It will be a socket being fed from the house main consumer unit. 2.5t&e will be OK for this?
Steve.
Stephen,
Is there a simpler way of just taking a spur from an existing socket? Or inserting the new socket in an existing ring ( this should be done by qualified electrician, but your suggested solution will also require qual. leccy as well)
1 hour ago, Stephen Goodey said:
It will be a socket
A single socket? Then that’s ok as a spur. As is a double socket I believe.
20 hours ago, BotusBuild said:
Stephen,
No, the way I'm thinking of doing it is the simplest. Thanks.
Steve.
