Direct waste connection to main drainage
Annker
Looking for some design feedback.
I have serval waste connections to make at ground floor level. Kitchen sink, disk washer and washer machine.
Previously (many years ago) I would have just ran the 40mm waste through the external wall at high level (~1m) and then connected to the main 110mm drain run via a gully trap.
I understand this arrangement is currently considered old school but regardless it is not suitable on this current job as I cannot have external surface fixed pipe work at this location.
Reading previous topic I have came up with the design below.
I'd appreciate if anyone can critique or suggest improvements.
TIA.
You need to bring the 110mm pipe up to the floor level with a 90⁰ long sweep rest bend. I section chamber on the outside where it connects to the main runn for rodding, rather than a rodding point on the inside.
I suppose that helps that rodding and resulting wastes is outside the building.
+1 We just brought 110mm up through the floor under the kitchen sink and used a rubber (?) adaptor down to 40 or 50mm. We have inspection chambers on all 110mm junctions outside.
I think all other rooms such as the downstairs WC have 110mm stub stack with AAV
5 hours ago, joe90 said:
Or like I did…(sorry about the CAD {crayon assisted drawing}.
3 hours ago, dpmiller said:
^ back entry gully trap for the win.
From reading here I know some people are fans of BIGT.
Perhaps I don't fully understand their function but doesn't the BIGT still have to connect to the main drainage run via an Inspection chamber?
I understand the BIGT provides a trap but is it not easier to provide the trap internal of the sink waste?
