nikki Posted May 21, 2024 Share Posted May 21, 2024 Hi. We bought a house with a large extension that had already been started which included the foundation and some of the blockwork. It was all signed off by building control before we bought it (according to the building control officer). Unfortunately, upon starting work to finish it our builder found that the foundation is not level (as was the blockwork 🤦🏼♀️) despite building control signing off on it all. My question now is: when we level the floor, should we do this with the screed layer on top of the insulation (so the screed will be thicker in some rooms) or should we level it out before we lay the insulation down so the screed on top will be an equal thickness across the whole extension. Or another options I haven’t thought of? The extension is approx 90m2 so it’s a fairly big area. Link to comment Share on other sites More sharing options...
Bonner Posted May 22, 2024 Share Posted May 22, 2024 Building control don’t care about being level, only meeting regulations. How much difference between high and lowest points? My subfloor was about 40mm out, I filled some low spots which reduced the difference to 20mm and made the rest up in the screed. Link to comment Share on other sites More sharing options...
Dave Jones Posted May 22, 2024 Share Posted May 22, 2024 is the floor or the walls out of level ? Have you checked its square ? Link to comment Share on other sites More sharing options...
nikki Posted May 22, 2024 Author Share Posted May 22, 2024 47 minutes ago, Bonner said: Building control don’t care about being level, only meeting regulations. How much difference between high and lowest points? My subfloor was about 40mm out, I filled some low spots which reduced the difference to 20mm and made the rest up in the screed. Thanks! I’ll check and report back. I think it might have been around 90mm though 🙃 1 Link to comment Share on other sites More sharing options...
nikki Posted May 22, 2024 Author Share Posted May 22, 2024 44 minutes ago, Dave Jones said: is the floor or the walls out of level ? Have you checked its square ? Both. Seems the original builder used a tape measure instead of a level when doing the walls as the walls followed the slope of the foundations. Our builder has fixed the walls now (we have roof on and windows in now) and they checked plum/square and the walls are all fine now. Just the foundation that’s still unlevel. We wanted to do the insulation on the floor ourselves though to save some money so need to figure out what the best approach is to handle the unlevel foundation issue 🙂 Link to comment Share on other sites More sharing options...
JohnMo Posted May 22, 2024 Share Posted May 22, 2024 14 minutes ago, nikki said: Thanks! I’ll check and report back. I think it might have been around 90mm though 🙃 Could you simply add more insulation in the low areas? Use EPS sheets to make up the difference - they are cheap enough. Link to comment Share on other sites More sharing options...
Jenki Posted May 22, 2024 Share Posted May 22, 2024 You don't mention your location, so assume not Scotland. For a detailed reply we need to know the dimensions, current floor make up, height between current build stage and FFL any. Details you have will help with a solution. What U value do you need to achieve? 1 Link to comment Share on other sites More sharing options...
saveasteading Posted May 22, 2024 Share Posted May 22, 2024 20 hours ago, nikki said: when we level the floor, should we I would suggest both. First to check...by foundations not level do you mean all the way up to floor level? Its very common for footings to go in to very poor level control. Lasers can make it worse as the builder who doesn't understand numbers assumes that the machine does. Then it can be corrected by the bricklayer who may use string-lines, which are sometimes more accurate.* A story for another day. If the perimeter at floor level is out, then that may cause all sorts of issues, so explain please. in principle though you can adjust the insulation level to maximise the potential, then the screed will make up the balance. 2 layers of insulation is good anyway as you can overlap the boards Link to comment Share on other sites More sharing options...
nikki Posted June 2, 2024 Author Share Posted June 2, 2024 On 22/05/2024 at 08:18, Jenki said: You don't mention your location, so assume not Scotland. For a detailed reply we need to know the dimensions, current floor make up, height between current build stage and FFL any. Details you have will help with a solution. What U value do you need to achieve? No, not Scotland. We’re in Mid West Wales. The floor level is off through out the entire extension (approx 90sqm). The difference in floor level is about 8cm in the worst part. It’s a gradual slope from one corner to another so it’s not just pockets of it that are unlevel - it’s the entire slab. FFL will be approx 15cm higher than current FL but obviously will be quite a bit higher than this in the lowest corners. I don’t have the u-value we need to achieve at the moment. The plans were submitted by the previous owner and never passed on to us when we bought the house. Waiting for building control to send them to us so we know the u-values needed for all aspects of the build (not just this). Our builder said 80mm celotex will be ok though. Link to comment Share on other sites More sharing options...
nikki Posted June 2, 2024 Author Share Posted June 2, 2024 On 22/05/2024 at 23:43, saveasteading said: I would suggest both. First to check...by foundations not level do you mean all the way up to floor level? Its very common for footings to go in to very poor level control. Lasers can make it worse as the builder who doesn't understand numbers assumes that the machine does. Then it can be corrected by the bricklayer who may use string-lines, which are sometimes more accurate.* A story for another day. If the perimeter at floor level is out, then that may cause all sorts of issues, so explain please. in principle though you can adjust the insulation level to maximise the potential, then the screed will make up the balance. 2 layers of insulation is good anyway as you can overlap the boards Yes all the way up to the current floor level. The difference is approx 8cm in the worst part. It’s a gradual slope across the entire slab so unfortunately it’s not just corners or pockets to be corrected. 2 layers of insulation in some areas might work I guess. I’m just trying to get my head around how that would work i.e. cutting a slope into the first layer or something. Link to comment Share on other sites More sharing options...
nikki Posted June 2, 2024 Author Share Posted June 2, 2024 On 22/05/2024 at 08:13, JohnMo said: Could you simply add more insulation in the low areas? Use EPS sheets to make up the difference - they are cheap enough. 2 layers of insulation in some areas might work I guess. I’m just trying to get my head around how that would work i.e. cutting a slope into the first layer or something. Unfortunately the current floor level is unlevel across the entire slab (90sqm) and not just corners or pockets so that makes it harder to fix I think. Difference of 8cm in the worst part. Link to comment Share on other sites More sharing options...
saveasteading Posted June 2, 2024 Share Posted June 2, 2024 6 hours ago, nikki said: how that would work i.e. cutting a slope into the first layer No slopes. Cover the whole area with the thickest board that the floor allows. Then add another layer on top, in one or two thicknesses. There will be steps but the screed takes care of that. Link to comment Share on other sites More sharing options...
nikki Posted June 2, 2024 Author Share Posted June 2, 2024 13 hours ago, saveasteading said: No slopes. Cover the whole area with the thickest board that the floor allows. Then add another layer on top, in one or two thicknesses. There will be steps but the screed takes care of that. Ah ok! That makes much more sense! Thank you! Link to comment Share on other sites More sharing options...
