Ed21 Posted May 3 Share Posted May 3 Hi all, I've changed an inaccessable stopcock burried deep in a small shaft to a much larger access pit with lid, but thought it might be prudent to add some insulation. So foam or foil wrap lying on ballast or just cover the whole pipe in ballast or is there a better way ? Any advice appreciated. Ed Link to comment Share on other sites More sharing options...
Conor Posted May 3 Share Posted May 3 How deep is the chamber? Normally, cover pipe with fine gravel, a EPS plug goes just under the lid. More than enough. 1 1 Link to comment Share on other sites More sharing options...
JohnMo Posted May 3 Share Posted May 3 We have a shallow chamber with pipes from borehole pump. With 25mm blue water pipe. 39 minutes ago, Conor said: EPS plug goes just under the lid Almost exactly what I did. But I had an off cut of 25mm PIR, so used that. Just made a circle to slip in the chamber. Been ok down to -7 for a week or more. Link to comment Share on other sites More sharing options...
Ed21 Posted May 3 Author Share Posted May 3 5 hours ago, Conor said: How deep is the chamber? Normally, cover pipe with fine gravel, a EPS plug goes just under the lid. More than enough. Sounds good It's 1.3m down and 32mm pipe. Got a raised rim, so a chunk of 100mm EPS close cut all the way around resting on a stop within the hole and some small gravel round the pipe is the way to go. Thanks for that ! Link to comment Share on other sites More sharing options...
Kelvin Posted May 3 Share Posted May 3 (edited) My borehole chamber is above ground although I’ll half bury it. I also used some 25mm PIR I had left over and wrapped all the pipes . I’ve also got a heated cable attached to a thermostat that I ran down the ducting the 32mm water pipe is in. Probably unnecessary. Edited May 3 by Kelvin Link to comment Share on other sites More sharing options...
saveasteading Posted May 3 Share Posted May 3 6 hours ago, Ed21 said: It's 1.3m down and 32mm pipe. That will not freeze. The ground down there is not affected by cold weather. gravel will keep cold air off the pipe a bit. however, the short section of pipe that is exposed is linked to the rest of the mains which has ambient water in it, occasionally being replaced when you run a tap. There is no harm in protecting it unless it makes maintenance or inspection difficult, hence a lump of eps or a bundle of bubble-wrap is pragmatic. Link to comment Share on other sites More sharing options...
