MariaD Posted May 1, 2024 Share Posted May 1, 2024 ICF-Field-Test-Report.pdf (bchousing.org) According to the tests documented in the above link, it would be better not to but windows buck for better air and water impermeability. Did any of you used or not used windows bucks for your own house? Link to comment Share on other sites More sharing options...
JohnMo Posted May 1, 2024 Share Posted May 1, 2024 Why would you use a window buck in an icf, unless you live in the states. Most the drawings in the paper give quite a thermal bridge. 1 Link to comment Share on other sites More sharing options...
FM2015 Posted May 1, 2024 Share Posted May 1, 2024 #structuralcheckreveal Link to comment Share on other sites More sharing options...
Chanmenie Posted May 2, 2024 Share Posted May 2, 2024 I didn’t, expanding tape between frame and reveal, airtight foam inside then brush on liquid membrane as a final air tight barrier 1 Link to comment Share on other sites More sharing options...
Nick Laslett Posted May 2, 2024 Share Posted May 2, 2024 20 hours ago, MariaD said: ICF-Field-Test-Report.pdf (bchousing.org) According to the tests documented in the above link, it would be better not to but windows buck for better air and water impermeability. Did any of you used or not used windows bucks for your own house? I read this report when I was researching ICF for my build. USA windows circa 2014 are very different to UK or European style casement windows. Back then they struggled to achieve water tightness, let alone air tightness. We don’t use this approach here. There are some older ICF systems that don’t deal with junctions very well. 1 Link to comment Share on other sites More sharing options...
