puntloos Posted April 23, 2024 Posted April 23, 2024 Wondering if this exists: I'm debating cutting a 1x1cm groove into a tile, laying a cable in it, and then putting a "french drain cover" over it. Does this exist? Is it a good idea? Photo below, but in miniature.
puntloos Posted April 23, 2024 Author Posted April 23, 2024 Floor power socket was placed in the wrong place, but it'll be under the carpet anyway, so leading a small cable duct from that socket to where the cable needs to actually come out seems the easiest way forward.
puntloos Posted April 23, 2024 Author Posted April 23, 2024 Maybe this could work - https://www.amazon.co.uk/Stainless-Thickness-Industry-Experiments-Maintenance/dp/B0C42RP1BJ/ref=sr_1_54
Russell griffiths Posted April 23, 2024 Posted April 23, 2024 Why are you cutting it 1cm, if it’s under carpet then cut a proper chase out fit proper plastic conduit and fill it back in with screed, carpet over the top.
puntloos Posted April 23, 2024 Author Posted April 23, 2024 2 hours ago, Russell griffiths said: Why are you cutting it 1cm, if it’s under carpet then cut a proper chase out fit proper plastic conduit and fill it back in with screed, carpet over the top. The problem is the underfloor heating, we can't be 100% sure where the pipes are, and accidentally cutting them isn't great. We can certainly inquire if we can go somewhat deeper, a 1cm pipe, and a tiny bit of screed on top could work....
Alan Ambrose Posted April 24, 2024 Posted April 24, 2024 (edited) Borrowing or renting a thermal camera (and turning the heating up for a few hours) may well tell you where the pipes are. And then maybe burying the cable in a bit of 20mm plastic conduit. Edited April 24, 2024 by Alan Ambrose 1
