johnhenstock83 Posted March 21, 2024 Share Posted March 21, 2024 hi all, I need a bit of help. we built an extension, all done now, more or less. walls are typical masonry walls (brick out, block in), hardwall plaster + skim. I painted the walls white, a think layer, seems to be holding ok. I now want to tile behind the gas hob, but not sure what preparations to make. how do I make sure my tiles will bond to the wall properly? PVA? do I scrape the wall? special adhesive? also, can someone recommend a ready made, decent adhesive for a DIY job? thank you! Link to comment Share on other sites More sharing options...
markc Posted March 21, 2024 Share Posted March 21, 2024 Any decent flexible tile adhesive should stick. What paint is it? If vinyl then you may find it will come away in sheets if you get behind it, if so peel it off where you are tiling, if it’s stuck well then tile over it. 1 Link to comment Share on other sites More sharing options...
Russell griffiths Posted March 21, 2024 Share Posted March 21, 2024 Soak with a sponge and the paint should wash off. key the surface up if it’s a bit shiny. 40 grit sandpaper will give it a key. 1 Link to comment Share on other sites More sharing options...
johnhenstock83 Posted March 21, 2024 Author Share Posted March 21, 2024 Thanks both. It’s a matte paint, wickes builder’s white paint, thin coat, doesn’t come off. Link to comment Share on other sites More sharing options...
Conor Posted March 21, 2024 Share Posted March 21, 2024 Score deeply in diamond patterns with edge of a scraper. 2 Link to comment Share on other sites More sharing options...
