5.5m flat roof span
Hi,
I have had a look and can’t see any definite answers to this. Apologies if I have missed it.
I am looking into what size of joists I need to use for my flat roof on the garden room. It has to span 5.5m with a 300 over hang at the front and 100 at the back. Going with 400 centres. Most of the span tables I have found do not suggest any size of timber for this however, I have seen quite a few videos where they have sistered 6x2 with bolts to help strengthen the joists but again, none of the spans were the same as mine.
The question I would like help with is, would sistered 6x2 roof joists be strong enough to carry cold roof and prevent future sagging?
Thanks in advance,
GRB
At 5.5m and flat roof so possible high snow loadings etc. I wouldn’t use solid timber, the self weight (unless looking at 200-250mm timbers) will tend to sag sistered or not, I would be looking at pozi’ joist or cold rolled purlins.
Sounds like a need for Web- or I-joists.
As a guide only (!) We have some 5.4m spans and had web joists at 400 c/c. Each joist was 300mm deep and 100mm wide. This is for a warm roof with green roof on top.
If you can afford it get a structural engineer to do the calculations for you, with the  caveat they will likely overspec for insurance purposes
Sounds like a span better suited to engineered posi/i-joists. Plenty of span tables online.
Have you tried contacting local joist suppliers? Given a set of plans they'll probably spec out the depth & spacing you need for free when quoting. Deeper but wider spaced may be cheaper if you're not height constrained.
How are the walls built? That's quite a roof. If it's block built you'd want a steel beam running the length to carry the joists so the span is halved.
The good old 1992 version of the Approved Document to Part A had a wide range of timber span tables in the appendix.
For a 5.5m clear span using C16 joists you'll need 63mm x 220mm @ 400mm cntrs assuming a dead load of no more than 0.5kN/m2 (excluding self weight) or 75mm x 220mm @ 400mm cntrs if the dead load is between 0.5 and 0.75kN/m2. Although C16 is not as common these days.
If you have C24 joists you could "get down" to 75mm x 195mm @400 cntrs for the lighter dead load.
But as been pointed out these are chunky bits of timber and open span joists may be cheaper in the long run.
Thanks. Based on all the replies, I reckon I’ll go for I-joists.
I had seen other projects using I-joists but could never see prices online. I will check with our local timber merchant and see what they say. Thanks for sharing your spec.
Thanks. Not sure I want to risk it with the c24 timbers. Going to investigate the I-joists a bit more now.
What's the other dimension of your garden room? If it's less than 5.5m, then why are you choosing to span the longer dimension?
EDIT: nevermind just seen your intro post - 6x5.5m, that's a huge space!!
Edited by oliwoodings
I seen your other comment. Your room was 6x5? What solution did you go for on the roof joists?
Mine is divided into two rooms, so the max span is actually 3.5m! I used 6m 2x7s for the joists with them resting on the interior partition wall.
Another thought on your suggestion of sistered joists - I considered this as well at one point, but realised it would tangibly reduce the thermal performance of the roof (because of the amount of timber Vs insulation), unless I went warm roof but then I couldn't get it under 2.5m. Also the cost of sistering became very unattractive compared to other options like I joists etc.
Good point. I’ve decided on I joists now. Going to speak to local timber merchant and see what they say.
