Tony K Posted February 16, 2024 Share Posted February 16, 2024 Afternoon all. I am about to prepare a bathroom for tiling. I attach a picture of the shower area which you can see is in a corner formed by an internal partition wall and an external cavity wall. I will use tile backer boards to complete the partition wall, and to box in the low pipes on the block wall. Should I be fixing tile backer boards to the face of the block wall generally, or is it OK to tile straight onto the blocks? My tiler is happy to tile onto the blocks if they are level but he is only responsible for the finish. I am thinking more about whether I need a continuous waterproof substrate on both walls, and whether block work provides one anyway. Any advice gratefully received! Link to comment Share on other sites More sharing options...
markc Posted February 16, 2024 Share Posted February 16, 2024 Nothing wrong with tiling onto blockwork but you have surface mounted pipes the tiles need to go over? Are these going to be boxed? Link to comment Share on other sites More sharing options...
Tony K Posted February 16, 2024 Author Share Posted February 16, 2024 7 minutes ago, markc said: Nothing wrong with tiling onto blockwork but you have surface mounted pipes the tiles need to go over? Are these going to be boxed? Yes, the lower part of the block wall will be boxed in using timber faced with tile backer boards so as to form a shelf in the shower area. Link to comment Share on other sites More sharing options...
Mr Punter Posted February 16, 2024 Share Posted February 16, 2024 The Wedi board XPS type boards are nice to use. Much easier to work with than the cement based likes of Hardi Backer. 1 Link to comment Share on other sites More sharing options...
Tony K Posted February 16, 2024 Author Share Posted February 16, 2024 34 minutes ago, markc said: Nothing wrong with tiling onto blockwork but you have surface mounted pipes the tiles need to go over? Are these going to be boxed? I have just seen a video on youtube in which care is taken to address the joins between the boards to ensure tat the substrate is waterproof. I suppose that is in case the grout fails or something. Do you think that the combination of backer boards and block wall will be OK as a waterproof substrate? Link to comment Share on other sites More sharing options...
markc Posted February 16, 2024 Share Posted February 16, 2024 (edited) 57 minutes ago, Tony K said: I have just seen a video on youtube in which care is taken to address the joins between the boards to ensure tat the substrate is waterproof. I suppose that is in case the grout fails or something. Do you think that the combination of backer boards and block wall will be OK as a waterproof substrate? Joints are the key, whether that is board to board, board to block etc. and especially corners. tanking paint and sealing tape work very well as the elasticity copes with and movement. And yes, getting the backing right is to prevent problems if - when the grout fails. It’s very easy to install a shower and do a bit of tiling but rotten plasterboard, wall studs and flooring is very common when water gets behind the tiles. Edited February 16, 2024 by markc 1 Link to comment Share on other sites More sharing options...
Tony K Posted February 16, 2024 Author Share Posted February 16, 2024 1 hour ago, markc said: Joints are the key, whether that is board to board, board to block etc. and especially corners. tanking paint and sealing tape work very well as the elasticity copes with and movement. And yes, getting the backing right is to prevent problems if - when the grout fails. It’s very easy to install a shower and do a bit of tiling but rotten plasterboard, wall studs and flooring is very common when water gets behind the tiles. Thanks @markc. I have just heard back from the tech dept of STS, the manufacturers of the backer boards I have. Interestingly, they say I do not need tape, just this stuff: https://www.wickes.co.uk/STS-Mega-Strength-PU-Adhesive---310ml/p/101132?fix&gad_source=1&gclid=CjwKCAiArLyuBhA7EiwA-qo80GBaJkYaeTyYQRfKm_5FBQ3PPmZUSGkYke6J4j4W6dFpoKPXr0ZnOhoCrX4QAvD_BwE&gclsrc=aw.ds Apparently, I use it not only to glue the boards to each other at the joins but also at the join between the boards and the block wall. They said I did not need tape, which slightly surprised me. Link to comment Share on other sites More sharing options...
Russell griffiths Posted February 16, 2024 Share Posted February 16, 2024 (edited) 5 hours ago, Tony K said: Edited February 16, 2024 by Russell griffiths Link to comment Share on other sites More sharing options...
nod Posted February 16, 2024 Share Posted February 16, 2024 (edited) I do hundreds of m2 of tiling on to backer boards each year Never tape Simply glue with a U nozzle Over the past 40 years I’ve tiled lots of wet rooms The past five years we have been using Impey tanking kits without any issues Not the cheapest though Edited February 16, 2024 by nod 1 Link to comment Share on other sites More sharing options...
