Evening, filling in Jeremy Harris heat loss calculator
I understand Jeremy built this to work out where best to spend his money in his build.
however if I want to use it to help understand the size of a heat pump I need, what should I put in the outside temperature box.
jeremy used minus 10, so probably the worst case scenario
should I use a more real world figure like 0 or minus 2, the met office is saying the average minimum temp in January is 1.23
whats best to get some real world figures out of it.
cheers. Russ.
