Lesgrandepotato Posted September 23, 2017 Posted September 23, 2017 So we started with a late 70's bungalow, oil fired central heating. Double glazed. Rated at 53 on the plan so a 'E'. During the build we have dug out the slab and insulated to building regs (I know! But there just wasn't space to get more than 70mm in) We haven't filled the cavities, but we have added 60mm internal insulation on all walls, we are mostly LED lit and we are fully triple glazed. 300mm in the loft. I'm not expecting miracles but what could it / should it be?
dogman Posted September 23, 2017 Posted September 23, 2017 Run your build through EPC software it should give you a new figure 1
SteamyTea Posted September 23, 2017 Posted September 23, 2017 It may be hidden in here: http://www.uk-ncm.org.uk/ 1
Lesgrandepotato Posted September 23, 2017 Author Posted September 23, 2017 Cheers guys :-) that's a really easy answer
dogman Posted September 23, 2017 Posted September 23, 2017 use stroma its free to download a trial version
MikeSharp01 Posted September 23, 2017 Posted September 23, 2017 1 hour ago, dogman said: use stroma its free to download a trial version Yes but be ready to look for the input (need more input...) it requires. One thing you can say for sure is that it will be better at keeping bills lower than it was although changes in the SAP calculation method, depends on when the original EPC was issued, might mean it does not move as far up the scale as you might hope or might move further. Essentially there is no way of knowing without doing the detail work, sorry.
A_L Posted September 23, 2017 Posted September 23, 2017 Since 53 is a 'high' E my guess is a 'C' at least half way up its range.
