What model is this oil pump - have a guess
cwr
Hi all
I need to replace this oil pump from a boiler. It's a Danfoss,  I can tell that much....
Unsurprisingly there appears to be a multitude of possible models it could be. Ideas ideas if where to go from here?
19 hours ago, cwr said:
Hi all
Why do you need to replace it, what part of it has failed? I only ask as I repaired a drive shaft/gear spline/key on one of these not long ago, it was pulsing the oil pressure and it turned out to be the gear slipping on the drive shaft.
Edited by Carrerahill
  • jack changed the title to What model is this oil pump - have a guess
the mount and shaft *should* be universal but there are some outliers. Direction of rotation and pipe positions are the critical bit, some of the other options (position of the regulator etc) may not be so important for most applications...
