lord mud of the flyes Posted January 17, 2024 Posted January 17, 2024 Hi Would like to build a septic tank for a static trailer The trailer will need moving once ever blue moon. So the tank will need to be emptied by a waste manengment company. Trouble is i dont know how a waste managment company would empty it and what kind of equipment they carry
nod Posted January 17, 2024 Posted January 17, 2024 If you are allowed a septic tank and not a treatment plant like most It would be easier to buy a fiberglass or plastic tank Dig a hole and drop it in If you build a traditional type tank It will have to be well away from the caravan Emptying is simple Tanker Suction hose
Duncan62 Posted January 17, 2024 Posted January 17, 2024 I use IBC tanks. One below invert for toilets etc. 3 above ground. Pump from one to other three in turn about once a month. Water removal is simple suction hose as mentioned above.
saveasteading Posted January 17, 2024 Posted January 17, 2024 3 hours ago, lord mud of the flyes said: dont know how a waste managment company would empty it and what kind of equipment they carry It's a tanker with a variety of hoses so they'll use a wide hose when possible and narrow one if necessary. They'd want to be within about 20m of the tank.
ProDave Posted January 17, 2024 Posted January 17, 2024 I have seen a low profile treatment plant designed to slide under the limited space under a static caravan. I will see if I can find it. Here it is https://www.theseptictankstore.co.uk/shop/marsh-portapura-m2-sewage-treatment-plant-2-person/ When you want to move the 'van, get the treatment plant pumped out and you can move that to the new location as well.
lord mud of the flyes Posted January 18, 2024 Author Posted January 18, 2024 22 hours ago, nod said: Emptying is simple Tanker Suction hose Dose that mean it has to be emptied fro the top of the tank and not the bottom?
lord mud of the flyes Posted January 18, 2024 Author Posted January 18, 2024 21 hours ago, Duncan62 said: I use IBC tanks. One below invert for toilets etc. 3 above ground. Pump from one to other three in turn about once a month. Water removal is simple suction hose as mentioned above. Again where is the whole for them to access this?
lord mud of the flyes Posted January 18, 2024 Author Posted January 18, 2024 20 hours ago, saveasteading said: It's a tanker with a variety of hoses so they'll use a wide hose when possible and narrow one if necessary. They'd want to be within about 20m of the tank. But do they suck out from the top with a vacume cleaning wand type pipe? or from under the tank; if so what couplings do they use?
lord mud of the flyes Posted January 18, 2024 Author Posted January 18, 2024 20 hours ago, ProDave said: I have seen a low profile treatment plant designed to slide under the limited space under a static caravan. I will see if I can find it. Here it is https://www.theseptictankstore.co.uk/shop/marsh-portapura-m2-sewage-treatment-plant-2-person/ When you want to move the 'van, get the treatment plant pumped out and you can move that to the new location as well. Sorry but that money is well out of budget! But there are 3 holes in the top of that tank; what do they do? Thanks
nod Posted January 18, 2024 Posted January 18, 2024 1 hour ago, lord mud of the flyes said: Dose that mean it has to be emptied fro the top of the tank and not the bottom? Normally the top Bit messy from the bottom 1
Duncan62 Posted January 18, 2024 Posted January 18, 2024 2 hours ago, lord mud of the flyes said: Again where is the whole for them to access this? Yes from the top. No coupler. It is simply an industrial vacuum. Any hole with diameter 15cm or greater will work.
lord mud of the flyes Posted January 18, 2024 Author Posted January 18, 2024 11 hours ago, Duncan62 said: Yes from the top. No coupler. It is simply an industrial vacuum. Any hole with diameter 15cm or greater will work. Well that may be difficult then as the tank sits under the trailer
saveasteading Posted January 18, 2024 Posted January 18, 2024 3 hours ago, lord mud of the flyes said: tank sits under the trailer There's usually a side cap too. I'm recollecting helping to clean my drains. One of the suction pipes easily went along a 100mm drain, so I think it was about 60mm OD.
lord mud of the flyes Posted January 19, 2024 Author Posted January 19, 2024 10 hours ago, saveasteading said: There's usually a side cap too. I'm recollecting helping to clean my drains. One of the suction pipes easily went along a 100mm drain, so I think it was about 60mm OD. This is to be a home build tank. But it would be nice to see a diagram of a tank as you say with a side cap on it. You say 60mm, is that the hole they would suck the waste from?
saveasteading Posted January 19, 2024 Posted January 19, 2024 60mm pipe. But that is approx, from distant memory. Why not extend the tank slightly and have cap on top?
lord mud of the flyes Posted January 21, 2024 Author Posted January 21, 2024 On 19/01/2024 at 10:28, saveasteading said: Why not extend the tank slightly and have cap on top? Where about from the diagram would you put it?
lord mud of the flyes Posted January 22, 2024 Author Posted January 22, 2024 (edited) 21 hours ago, saveasteading said: Near the top. But these no room to fit! Edited January 22, 2024 by lord mud of the flyes
ProDave Posted January 22, 2024 Posted January 22, 2024 2 hours ago, lord mud of the flyes said: But these no room to fit! Because you are trying to design it using a big fat round barrel. There is a reason the one I linked to designed for the job is larger, but a lot flatter.
lord mud of the flyes Posted January 22, 2024 Author Posted January 22, 2024 5 hours ago, ProDave said: Because you are trying to design it using a big fat round barrel. There is a reason the one I linked to designed for the job is larger, but a lot flatter. Even still with one of those tanks; how would I get access to it, if the top was right under the trailer flooring
lord mud of the flyes Posted January 24, 2024 Author Posted January 24, 2024 OK best forget about it then Buy!
