Condensation in the unit
So far there has been no condensation in my DIY unit.
However, I am in the design stage of DIY unit 1.1 which will be a much better insulated twin core model.
Am I right in thinking, should any condensation form, it will be in the extract (from home) chamber and that is where I should put a drain? Just in case.
Depends did you get a standard or enthalpy heat exchanger.
The enthalpy ones recycle the moisture back into the incoming air. So no condensation will accumulate.
  • 2 months later...
24 minutes ago, Coanda said:
I'm wondering, does any air get sucked in through the condensate drain?
 the water in the trap is enough to stop the "sucking".
On 01/03/2024 at 11:23, Roundtuit said:
They frequently discharge into the house waste plumbing, so should have a trap on it.
Does the condensate pipe need to be 40mm?, was thinking of using overflow pipe and chasing it into the wall in order to get it to a drain in our utility. Don't want to be boxing in. Would over flow pipe work?
Don't see why not, then drop it into a waterless trap in the utility.  The condensate pipe out of my unit is overflow sized; it's only taking a trickle at worst.
