Chris HB Posted December 12, 2023 Author Share Posted December 12, 2023 @Iceverge do you how robust the structure/outsides are of these refrigerator units as I’m unsure as to how they are actually made? I’m assuming they’ll be fairly robust, but obviously not a steel container so a bit lighter overall. Link to comment Share on other sites More sharing options...
Iceverge Posted December 12, 2023 Share Posted December 12, 2023 If it's not handy to get you may as well source a 40ft one. The haulage will be similar I'd have thought. Link to comment Share on other sites More sharing options...
Iceverge Posted December 12, 2023 Share Posted December 12, 2023 9 minutes ago, Chris HB said: @Iceverge do you how robust the structure/outsides are of these refrigerator units as I’m unsure as to how they are actually made? I’m assuming they’ll be fairly robust, but obviously not a steel container so a bit lighter overall. I'm not sure exactly. I think steel frames with polyurethane insulation skinned with light gauge steel externally and plastic inside. You can get Reefer Containers which can be stacked like regular containers so they must be pretty strong. Link to comment Share on other sites More sharing options...
saveasteading Posted December 12, 2023 Share Posted December 12, 2023 37 minutes ago, Iceverge said: they must be pretty strong. I think these are craned and forklifted the same as the obviously strong steel ones. The reason for selling them off is presumably the chiller being at end of life...or the door, which must be insulated too. Link to comment Share on other sites More sharing options...
SteamyTea Posted December 12, 2023 Share Posted December 12, 2023 2 hours ago, Iceverge said: I think steel frames with polyurethane insulation skinned with light gauge steel externally and plastic inside. How would they stand up to fire regulations when converted to a building? Link to comment Share on other sites More sharing options...
Chris HB Posted December 12, 2023 Author Share Posted December 12, 2023 25 minutes ago, SteamyTea said: How would they stand up to fire regulations when converted to a building? Not planning on converting it to a proper building, more temporary onsite storage mainly. Me sleeping on the floor or using it as a temporary site office sort of thing will be temporary… hopefully! 🤣 Link to comment Share on other sites More sharing options...
saveasteading Posted December 12, 2023 Share Posted December 12, 2023 4 hours ago, SteamyTea said: stand up to fire regulations Not far to the fire exit. 1 Link to comment Share on other sites More sharing options...
Iceverge Posted December 13, 2023 Share Posted December 13, 2023 I've had a scan of your blog. You seem to have a couple of requirements/challenge's In no particular order. 1. A place that you can store stuff. 2. A camp out while working on the project. 3. Something that won't be blown away. 4. Something that you can establish without permission. 5. Something that can be used later for an office/workspace. 6. Something cheap to establish. In you location I think unless you can get a local unit it's going to be cheaper to just build something permanent on permitted development. A simple metal framed shed would be fine and last a long time without all the compromises of a container. @Kelvin has one if I remember search his build thread. Link to comment Share on other sites More sharing options...
Kelvin Posted December 13, 2023 Share Posted December 13, 2023 (edited) Yes it’s an insulated steel garage/workshop. Sheets come in various thicknesses of insulation starting at 40mm. Mine is 80mm. I probably wouldn’t go less than 80mm. It’d be much dearer than an insulated container of course. Needs to sit on a foundation so there’s that cost too. I put 100mm of insulation under the concrete slab. It’s unheated currently and quite useable as long as you’re doing something. Edited December 13, 2023 by Kelvin Link to comment Share on other sites More sharing options...
saveasteading Posted December 13, 2023 Share Posted December 13, 2023 1 hour ago, Kelvin said: Sheets come in various thicknesses of insulation starting at 40mm. Meaning composite panel? Steel outer and inner, filled with PIR. Avoid the cheaper polyurethane versions. They burn and are rightly uninsurable. Link to comment Share on other sites More sharing options...
Kelvin Posted December 13, 2023 Share Posted December 13, 2023 30 minutes ago, saveasteading said: Meaning composite panel? Steel outer and inner, filled with PIR. Avoid the cheaper polyurethane versions. They burn and are rightly uninsurable. Yes exactly that. Link to comment Share on other sites More sharing options...
Chris HB Posted December 15, 2023 Author Share Posted December 15, 2023 (edited) On 13/12/2023 at 00:32, Iceverge said: I've had a scan of your blog. You seem to have a couple of requirements/challenge's In no particular order. 1. A place that you can store stuff. 2. A camp out while working on the project. 3. Something that won't be blown away. 4. Something that you can establish without permission. 5. Something that can be used later for an office/workspace. 6. Something cheap to establish. In you location I think unless you can get a local unit it's going to be cheaper to just build something permanent on permitted development. A simple metal framed shed would be fine and last a long time without all the compromises of a container. @Kelvin has one if I remember search his build thread. Good summary! 👍 With foundations, planning permissions, warrents and then the construction itself, I think this will be way more expensive than your initial suggestion of the insulated refrigeration unit. Transportation worst case so far is going to be say £2,200, so approx £4,200 delivered. Could a metal shed with composite panels and foundations etc. compete with that cost-wise? The refrigeration unit also has the possible option of resale if I no longer want to use it as a studio space. Edited December 15, 2023 by Chris HB Link to comment Share on other sites More sharing options...
Iceverge Posted December 15, 2023 Share Posted December 15, 2023 You can build a shed under permitted development no? Link to comment Share on other sites More sharing options...
Chris HB Posted December 15, 2023 Author Share Posted December 15, 2023 2 hours ago, Iceverge said: You can build a shed under permitted development no? Not sure, as technically it would not currently be classed as a dwellinghouse – part of the planning permission is to get it classed as residential in the first place, as a church meeting hall it was possibly classed as commercial (or suis generis) initially. It also means that although it is 110 years old, it gets classed as a new build as well! 🤪 Also, the ideal space for the location is to the side of the building, whereas the regs state it would have to be that it's located at the back of the house. Interesting… https://www.mygov.scot/build-shed-garage-greenhouse Link to comment Share on other sites More sharing options...
Iceverge Posted December 15, 2023 Share Posted December 15, 2023 Right no planning. Been there, mad to get chomping at the bit and start hammering bits of timber together but frustrated by the bureaucracy. You have 2 proper options at the moment. 1. To hell with the planning, move into the hall as is and and ask for forgiveness later. It'll require an absence of grumpy neighbours a pot of ready cash and risks peeing off the planners. 2. Hammer the paperwork now. There'll be enough physical work later for the build. Get your permits in place the.build something appropriate for task and not a compromised stopgap. In my experience nibbling away at a big project with limited funds will burn out your enthusiasm before the dream is realised. 1 Link to comment Share on other sites More sharing options...
Chris HB Posted December 16, 2023 Author Share Posted December 16, 2023 19 hours ago, Iceverge said: Right no planning. Been there, mad to get chomping at the bit and start hammering bits of timber together but frustrated by the bureaucracy. You have 2 proper options at the moment. 1. To hell with the planning, move into the hall as is and and ask for forgiveness later. It'll require an absence of grumpy neighbours a pot of ready cash and risks peeing off the planners. 2. Hammer the paperwork now. There'll be enough physical work later for the build. Get your permits in place the.build something appropriate for task and not a compromised stopgap. In my experience nibbling away at a big project with limited funds will burn out your enthusiasm before the dream is realised. Yep, got my design ideas resolved for the building, it's then getting the drawings and details for planning and warrants etc. started mid-January, hoping to get planning/warrants sorted in June/July all being well. At the moment I have a small tent set-up inside the building to camp out in, but I’m aware that when work in proper starts, the floor etc. will be coming up, and camping in the building will no longer be an option, plus I will need extra storage for the floorboards and stuff I have in the building at the moment. Luckily I have a concrete bus shelter and a store for the funeral bier that I’m trying to make usable storage spaces in the meantime. Link to comment Share on other sites More sharing options...
Chris HB Posted December 17, 2023 Author Share Posted December 17, 2023 I have also found a refrigerated shipping container, that potentially saves the hassle of getting things framed out and insulated as it would already be done… 2 Link to comment Share on other sites More sharing options...
SteamyTea Posted December 17, 2023 Share Posted December 17, 2023 4 hours ago, Chris HB said: I have also found a refrigerated shipping container, that potentially saves the hassle of getting things framed out and insulated as it would already be done… And it will keep the vegans away. Link to comment Share on other sites More sharing options...
