Can plasterers finish internal/external corners and feather out without having to do the whole walls?
Trying to save some money on having newly plaster boarded walls finished. I’d just tape and fill the other joints myself.
Thanks!
If you can do a vertical or horizontal joint between two boards you can do the corners, I would say filling up to a corner bead is easier.
Make sure you use drylining beads and not skim beads, drylining are shallower.
