benben5555 Posted November 1, 2023 Posted November 1, 2023 What insulation have people used in new build timber frame walls of 140mm depth. Looking to use mineral wool batts or roll. There seem to be a few options (Isolver / Rockwool) but none seem to be readily available on the internet. I want something that is easy to fit and effective. Thanks
SteamyTea Posted November 2, 2023 Posted November 2, 2023 Have a look at blown in cellulose insulation. 1
JohnMo Posted November 2, 2023 Posted November 2, 2023 Knauf Frametherm 32, on a roll, easy to cut, self supporting. Makes it easy to get a gap free install. Assume to get a decent U value, you have additional insulation going into the structure? 1
ProDave Posted November 2, 2023 Posted November 2, 2023 +1 for Frametherm 32 But what else are you using? 140mm insulation in a timber frame is not enough on it's own. So what else, external wall insulation, something over the inside of the frame? It needs to be designed as a whole package.
benben5555 Posted November 2, 2023 Author Posted November 2, 2023 There is 50mm PIR going over the studs internally. Frametherm 32 is about £24/m2. Rockwool flexi slab is £14/m2 (slightly lower thermal conductivity), has anyone used that?
