Critique this wall build up please
LiamJones
The logic behind some choices;
- the 70mm cavity, this is to allow the extension to match the existing cavity and avoid a tricky detail/thermal bridge between new and existing.
- the external wall insulation, this will be being added to the existing walls, so it makes sense to run it through flush on the extension.
N.b, plasterboard to be dot and dabbed to aerated concrete block, struggled to model it.
I've also not included weep vents, i don't think i need them?
Wot he says.
You've basically made an ICF analogue but with none of the benefits.
I wouldn't be using EWI on block, it's probably the most expensive way of doing it. Either ICF or standard cavity with the face of the block (plus scratch coat) in line with the EWI, with the one render system over the lot.
Thanks for your comments @Russell griffiths @Conor @MikeGrahamT21
I want to use the same build up for the whole building, putting ICF on the end of a block cavity bungalow complicates things. It's only a small extension and i;ve got brick layers lined up to start in a week. I originally posted this more to check block choices and the dpc/weep vent requirements. To me, it just seems simpler to keep it all the same. Especially given i need to solve this problem on the existing bungalow.
Regarding interstatial condensation, i modelled it using 0c/20c with no condensation. -5c/20c does have some condensation, but appears to be significantly less than the existing and within acceptable ranges, fully evaparorating in the drying season.
If i swap the aerated blocks on the inner leaf to solid blocks, i can further reduce the condensate, and move the condesation point to outside the cavity. This reduces the uvalue by 0.02, but within regs (0.18 for new elements on exisitng dwellings)
I'm no expert on interstatial condesation, but it all looks okay and within range. what am i missing?
Thanks, Liam.
Hi, thanks for all your opinions and advice!
I’ve decided to go with medium density blocks to both skins. Combined with the EPS bead cavity and EWI gives me a very small condensate point way out in the render and a u value of 0.16.
Here it is going up
I landed on the medium density blocks as a happy middle ground
lightweight/aerated
Low thermal conductivity
Low sound attenuation
lightweight for the bricklayers, less labour
more expensive material
more fragile, less ability to fix things to.
less airtight
heavy density
High thermal conductivity
high sound attenuation
heavier for bricklayers, more labour
less expensive material
High ‘thermal mass’
Better airtightness
medium density’s sat in the middle for all of these properties and are a good balance in my opinion.
Edited by LiamJones
Formatting
