crispy_wafer Posted September 27, 2023 Share Posted September 27, 2023 13 minutes ago, Pocster said: That’s it ! Cannot resist ! Winner ! You can half a twix for that effort! Link to comment Share on other sites More sharing options...
Pocster Posted September 27, 2023 Share Posted September 27, 2023 Just now, crispy_wafer said: You can half a twix for that effort! Only half ! Ffs ! 1 Link to comment Share on other sites More sharing options...
Triassic Posted September 30, 2023 Author Share Posted September 30, 2023 On 26/09/2023 at 18:28, Pocster said: Won’t post mine . But mine is bigger ! ; much bigger . Like big , bigger ! I did that in the last house. I used less that 1/4 of them. In the end I ‘hid’ the rest inside a false wall, never to be seen again. 1 Link to comment Share on other sites More sharing options...
Pocster Posted September 30, 2023 Share Posted September 30, 2023 1 minute ago, Triassic said: I did that in the last house. I used less that 1/4 of them. In the end I ‘hid’ the rest inside a false wall, never to be seen again. Tbh most exist just for poe reasons . Link to comment Share on other sites More sharing options...
SteamyTea Posted October 1, 2023 Share Posted October 1, 2023 Why not just run some T&E when installing the CAT cables. Costs 40p/m from Screwfix. Link to comment Share on other sites More sharing options...
joth Posted October 2, 2023 Share Posted October 2, 2023 15 hours ago, SteamyTea said: Why not just run some T&E when installing the CAT cables. Costs 40p/m from Screwfix. Then it all needs to be run in safe zones. Or do you mean to put low voltage done? The benefit of PoE is only one outlet and connector needed. Not sure what you'd terminate T&E at the wall with for low voltage connection without it looking a mess. The major cost of PoE is not the cable but the a switch with sufficient PoE budget. This is defo where a patch panel comes into its own (easily able to balance exactly which ports have PoE over time) Link to comment Share on other sites More sharing options...
SteamyTea Posted October 2, 2023 Share Posted October 2, 2023 2 minutes ago, joth said: Then it all needs to be run in safe zones. Yes. Probably sensible to do that anyway. Sooner or later someone will come along with a drill. Could run it as low voltage, but why bother, just more 'things' to buy. Link to comment Share on other sites More sharing options...
