getting to the point of needing to parge the celcon block walls for airtightness.
Was thinking rather than brushing in sand/cement slurry to spray on a covering of cheap emulsion.
Would it give a similar air tightness as parge ?
Maybe, but maybe not and most likely not. If it worked no one do large coating, they would just get of tins of emulsion. Or use a proper airtight paint.
Builders sand, cement and lime, is an easy enough task. It's flexible enough to withstand a bit of building movement. Took two of us, just under two days, to do 70m by an average of 3m high.
I really can’t imagine emulsion doing a great job, I could only see a thick latex type paint doing a proper job of air tightness but saying that sand cement slurry is cheap and easy to do.
Spend extra time sealing the dot and dab
Parge for Airtightness is a waste of time and money
As soon as your dry liners see the Parge They will cut corners
I use 100s m2s per year Never for airtightness Other than the odd self builder Always soundblock As it says on the bags
wet plaster it is then.
I’m doing mine in dot and dab
I could easily wet plaster
But you can get just as good airtightness with both
