Hilldes Posted September 6, 2023 Posted September 6, 2023 Any Loxone owners used a Loxone Wallbox as an EV charger? Any benefits for Loxone integration in this product as opposed to non Loxone EV charger outlets? https://shop.loxone.com/enuk/wallbox-tree.html
Dan F Posted September 6, 2023 Posted September 6, 2023 (edited) 1 hour ago, Hilldes said: Any Loxone owners used a Loxone Wallbox as an EV charger? Any benefits for Loxone integration in this product as opposed to non Loxone EV charger outlets? https://shop.loxone.com/enuk/wallbox-tree.html Potentially a good idea if you want to: - Implement access (e.g. via NFC) to enable charging. - Control charging current from Loxone. - Want to incorporate energy monitoring within the charger. I purchased a Tesla charger before these were released and while there is some data you can pull from Loxone (with some work), you can't control access, charging or charge current. That said: - With battery storage, my view is that there is no/minimal value in controlling current when you have a battery as a buffer. instead, you can use on/off control based on tariff and battery SoC. - I don't currently have a need to control charging, as the 2-5 a.m. schedule @ 11.5kW is enough to dump up to 35kWh (45%) overnight into the car, and charging using PV doesn't make sense on the current Octopus Flux tariff. - I can pull the total consumption from the Telsa charger API very easily for monitoring, so this solves this requirement for me, without needing to install a costly Modbus energy meter. - Access isn't that important for us given the charger is on a private drive, but the Tesla charge does actually let you limit to specific VINs. This isn't a flexible as a Loxone-based solution though. If I was buying one now would I get the Loxone one? I'm not sure, but I would seriously consider it, just from an ecosystem and simplicity perspective. Edited September 6, 2023 by Dan F
Hilldes Posted September 6, 2023 Author Posted September 6, 2023 Thanks @Dan F. Much appreciated. My setup is simpler in that I don’t currently have PV or battery storage. I did google for reviews of the Loxone Wallbox but got no hits apart from Loxone marketing materials.
Johnnyire Posted July 12 Posted July 12 On 06/09/2023 at 20:50, Dan F said: Potentially a good idea if you want to: - Implement access (e.g. via NFC) to enable charging. - Control charging current from Loxone. - Want to incorporate energy monitoring within the charger. I purchased a Tesla charger before these were released and while there is some data you can pull from Loxone (with some work), you can't control access, charging or charge current. That said: - With battery storage, my view is that there is no/minimal value in controlling current when you have a battery as a buffer. instead, you can use on/off control based on tariff and battery SoC. - I don't currently have a need to control charging, as the 2-5 a.m. schedule @ 11.5kW is enough to dump up to 35kWh (45%) overnight into the car, and charging using PV doesn't make sense on the current Octopus Flux tariff. - I can pull the total consumption from the Telsa charger API very easily for monitoring, so this solves this requirement for me, without needing to install a costly Modbus energy meter. - Access isn't that important for us given the charger is on a private drive, but the Tesla charge does actually let you limit to specific VINs. This isn't a flexible as a Loxone-based solution though. If I was buying one now would I get the Loxone one? I'm not sure, but I would seriously consider it, just from an ecosystem and simplicity perspective. Dan, can you assist me not sure if you are a partner or not. I have a loxone wallbox and a single phase loxone meter, I am powering the wallbox with a ultra ev cable which has the combined CAT and power cable. Can you explain the wiring set up for this in terms of where the data cables need to go and the loxone meter? The issue I have is the wallbox is obviously powered from the consumer unit but I presume the cat cable needs to go to the Loxone panel or something? Thanks
Thorfun Posted July 13 Posted July 13 (edited) 9 hours ago, Johnnyire said: Dan, can you assist me not sure if you are a partner or not. I have a loxone wallbox and a single phase loxone meter, I am powering the wallbox with an ultra ev cable which has the combined CAT and power cable. Can you explain the wiring set up for this in terms of where the data cables need to go and the loxone meter? The issue I have is the wallbox is obviously powered from the consumer unit but I presume the cat cable needs to go to the Loxone panel or something? Thanks @Rob99 is a Loxone installer and might be able to help if @Dan F doesn’t know the answer. but also the Loxone documentation on their website normally has all the connection information you need Edited July 13 by Thorfun Tagging Dan 1
