SilverShadow Posted August 13, 2023 Posted August 13, 2023 Hey all, Back once again, for more sage suggestions from you savvy bunch We have an attic room that we'd like to add an electric radiator to. Can anyone recommend a decent one around the £300-£350 Mark please? Seen a few by Rointe, Harmoni, Haverland, Dimplex, etc & they all look great. But I know in real life some are better than others in terms of build quality/reliability, etc A little about what it's for: ● Attic room, 3.5 × 2.5m2 ● 1 double glazed Velux window ● Minimal insulation between sloping roof part of room ● Part of a terrace A little about what we'd like: ● Wall mountable ● Around 1kw I'd guess? ● Decent warranty ● modernish design (to match our house look) ● if possible, also controlled by WiFi (tho we'd prefer a 'non subscription' based app/solution for that) I also wondered how easy it'd be to buy/fit a decent controller with WiFi to this, as it matches the other radiators we have: https://www.bestheating.com/milano-aruba-electric-white-horizontal-designer-radiator-single-panel-635mm-tall-choice-of-width-91838 Anything I've missed please feel free to ask Many thanks for your time 😀 Shadow
JohnMo Posted August 13, 2023 Posted August 13, 2023 First I would go for a more powerful one, a decent one will let you select the power output you need. You can then fine tune the output, if your 1kW ends up on the small size it just runs all the time. Also make sure it has a built in timer function and thermostat, so you only heat when you need to. Makes models? The other option choose any radiator you like. Add an element say 2kW and have a remote timer thermostat so it actually measures room temp. You just fill with water and some car antifreeze. More choice more adaptability. 1
SilverShadow Posted August 13, 2023 Author Posted August 13, 2023 Hey there - thanks for replying Don't really have anything specific in mind yet, but these seemed to fit the bill https://www.heatershop.co.uk/dimplex-q-rad-qrad100e-electric-radiator-1000w?cat=6170 https://www.heatershop.co.uk/harmoni-lugo-hs1100-electric-radiator-1100w-wifi?cat=5980 From what i can gather, something around 1kw+ should be enough for the room I was considering adding an element like you mentioned. But was hoping for something with a decent display/programme options & controllable by WiFi (not sure what there is)
SteamyTea Posted August 13, 2023 Posted August 13, 2023 Be careful when choosing and 'remote control' that is cloud based, the service can be pulled anytime the provider feels like it. As @JohnMo says, go bigger. The room warm up times will be faster as well. 1
SilverShadow Posted August 13, 2023 Author Posted August 13, 2023 Good call with cloud services. I know some folks control their heating/lighting with generic 3rd party apps. So was hoping I could use similar
TonyT Posted August 13, 2023 Posted August 13, 2023 9 hours ago, JohnMo said: First I would go for a more powerful one, a decent one will let you select the power output you need. You can then fine tune the output, if your 1kW ends up on the small size it just runs all the time. Also make sure it has a built in timer function and thermostat, so you only heat when you need to. Makes models? The other option choose any radiator you like. Add an element say 2kW and have a remote timer thermostat so it actually measures room temp. You just fill with water and some car antifreeze. More choice more adaptability. I like the second option, was actually thinking about this the other week for a small towel rail radiator.
SilverShadow Posted August 14, 2023 Author Posted August 14, 2023 Thanks for that. I think I will probably opt for this one - heats a room 50% bigger than ours, so should be fine: https://store.rioheating.com/products/rio-eco-1500w?variant=36968783446080¤cy=GBP&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad=1&gclid=Cj0KCQjwoeemBhCfARIsADR2QCsk1DSYaPooFAGu1PzBzgWtPk8fd9hSeesXyYozzuGJX1t-3hHtnMAaAiIXEALw_wcB
SteamyTea Posted August 14, 2023 Posted August 14, 2023 (edited) 8 minutes ago, SilverShadow said: think I will probably opt for this one Thought you wanted something contemporary, not a pastiche of a 1920 cast iron radiator. For similar money you can get an A2AHP. Even more 'Ultra Efficient' than a 'ceramic core'. My 1980s storage heaters have ceramic cores, called bricks. Edited August 14, 2023 by SteamyTea 1
SilverShadow Posted August 14, 2023 Author Posted August 14, 2023 Am guessing, but contemporary for £300-£350 might be a bit tricky 😉 Tbf, its not space age, but still a long way from the old cast iron rads of yester-century Was there something specific that would meet the price range & just be a wall mountable unit with simple installation? 🤔
TonyT Posted August 15, 2023 Posted August 15, 2023 Have you considered a free standing oil heater controlled via a smart plug? 1
SilverShadow Posted August 16, 2023 Author Posted August 16, 2023 Many thanks for your sound advice 😀 We opted against oil filled in case of leaks & preferred to avoid free standing units. We're hoping to sell the house later this year - we wanted something sturdier than just a free wheel oil radiator, but didn't want to break the bank either. Electric rads seemed like the best choice. Great to get your input to help with the decision making 👍 Shadow
