vagrantly3893 Posted July 18, 2023 Posted July 18, 2023 (edited) I recently plasterboarded my ceiling and I am left with some larger gaps between the edge of the board and the wall. How should I fill these gaps? Edited July 18, 2023 by vagrantly3893
Temp Posted July 18, 2023 Posted July 18, 2023 Every house I've had including our selfbuild has suffered from a problem in this area. The plasterboarded ceiling shrinks and the plaster cracks where ceiling meets wall. Unfortunately the crack isn't always right at the junction. If it was it would be easy to fix. Instead its frequently a few inches down the wall in places and a strip of plaster comes away from the wall. For that reason I'm not going to suggest you fit tape over the gaps, or at least if you do I don't recommend lapping it down the wall. Any plasterers out there got a solution for this? 1
vagrantly3893 Posted July 18, 2023 Author Posted July 18, 2023 21 minutes ago, Temp said: Every house I've had including our selfbuild has suffered from a problem in this area. The plasterboarded ceiling shrinks and the plaster cracks where ceiling meets wall. Unfortunately the crack isn't always right at the junction. If it was it would be easy to fix. Instead its frequently a few inches down the wall in places and a strip of plaster comes away from the wall. For that reason I'm not going to suggest you fit tape over the gaps, or at least if you do I don't recommend lapping it down the wall. Any plasterers out there got a solution for this? Those are actually Fermacell boards rather than plasterboards. You can hit them with a hammer and won't do any damage, so the boards themselves are very tough. The ceilings and walls won't be plastered. Elsewhere I've been recommended expanding foam.
TonyT Posted July 19, 2023 Posted July 19, 2023 SBR primer bonding coat to fill the gap, ready for suitable finish?
vagrantly3893 Posted July 19, 2023 Author Posted July 19, 2023 19 minutes ago, TonyT said: SBR primer bonding coat to fill the gap, ready for suitable finish? We plan to wallpaper the ceiling with wood chip
Mr Punter Posted July 19, 2023 Posted July 19, 2023 Why on earth are you using Fermacell on a ceiling?
vagrantly3893 Posted July 19, 2023 Author Posted July 19, 2023 56 minutes ago, Mr Punter said: Why on earth are you using Fermacell on a ceiling? Why not use it on a ceiling?
TonyT Posted July 19, 2023 Posted July 19, 2023 2 hours ago, vagrantly3893 said: We plan to wallpaper the ceiling with wood chip How’s the hot tub Time Machine working? 1
vagrantly3893 Posted July 19, 2023 Author Posted July 19, 2023 Just now, TonyT said: How’s the hot tub Time Machine working? We live in Germany. Anything else isn't allowed.
Mr Punter Posted July 19, 2023 Posted July 19, 2023 2 hours ago, vagrantly3893 said: Why not use it on a ceiling? It is expensive, heavy, difficult to cut, fix and finish and you don't get the benefits of impact resistance and pull-out strength where you would on a wall. 1
vagrantly3893 Posted July 19, 2023 Author Posted July 19, 2023 1 minute ago, Mr Punter said: It is expensive, heavy, difficult to cut, fix and finish and you don't get the benefits of impact resistance and pull-out strength where you would on a wall. All good reasons. My step father wanted to use it and considering I had no experienced I went with it. We used a board lift which helped, but positioning it accurately so there is a 5-7mm gap between boards for the filler was hard. It's also possible to glue the edges instead of using filler which would have been easier. I also like that for a quality 2 finish (wallpaper), we only need to fill the gap between the boards. No taping and feathering with filler. I think I'll try plasterboard for another room to compare the process.
