buildman Posted July 10, 2023 Posted July 10, 2023 Building drawings says 25mm upstand around all external walls. So what about along internal block walls ? another grey area?
Nickfromwales Posted July 10, 2023 Posted July 10, 2023 16 minutes ago, buildman said: Building drawings says 25mm upstand around all external walls. So what about along internal block walls ? another grey area? Are these kickers on a block and beam?
buildman Posted July 11, 2023 Author Posted July 11, 2023 perimeter insulation on external walls. so what about internal block walls? they are on 100mm insulation so the concrete slab will be level with top of upstands / perimeter insulation 25mm
Andeh Posted July 11, 2023 Posted July 11, 2023 We Insulated around internal walls as well, no harm in doing so and might help with thermal bridging a bit! Also more help for any settlement/expansion.
Nickfromwales Posted July 11, 2023 Posted July 11, 2023 25 minutes ago, buildman said: No body knows the answer😂 I’m a bit lost as to how your internal block walls are on 100mm of insulation? That and busy as feck 😣
buildman Posted July 11, 2023 Author Posted July 11, 2023 extension is several rooms with internal block walls built from footings. plans say external walls with upstands. so just the cavity walls or internal block walls as well.
Temp Posted July 11, 2023 Posted July 11, 2023 Im going to say both. The perimeter insulation acts as a thermal break on outside walls and as an expansion gap/buffer on all walls. Without it if the slab expands there is a risk the wall can be pushed sideways. Not much but enough to crack mortar joints or the blocks.
eandg Posted July 11, 2023 Posted July 11, 2023 You get 8mm perimeter strips for your internal walls. Blue foamy gear, cheap as online or four times as dear if you need to run to Screwfix the night before your screed pour like some idiots.
