Kelvin Posted July 11, 2023 Posted July 11, 2023 27 minutes ago, Dan F said: Drop ceiling where you have this? That's what we had to do.. It’s too low to do that (2250mm) I don’t mind the industrial look. When we come to board the ceiling we’ll take the ducting down board the ceiling and put it back up again.
Dan F Posted July 11, 2023 Posted July 11, 2023 (edited) @puntloos Why don't you put your MVHR near the outside wall? Your ducts to the exterior as they are will need a lot of insulation if you want to keep your PHPP person happy, also you'll lose a small amount of MVHR efficiency. How about: - Consumer unit next to the door. - Loxone where it is but higher up, with cupboards (reduced depth due to ducting at read) above the Loxone panel. - MVHR on the same wall, but all the way over to the right, ideally at a height that makes changing filters doable without a stepladder. Edited July 11, 2023 by Dan F
puntloos Posted July 11, 2023 Author Posted July 11, 2023 (edited) 36 minutes ago, Dan F said: @puntloos Why don't you put your MVHR near the outside wall? Your ducts to the exterior as they are will need a lot of insulation if you want to keep your PHPP person happy, also you'll lose a small amount of MVHR efficiency. How about: - Consumer unit next to the door. - Loxone where it is but higher up, with cupboards (reduced depth due to ducting at read) above the Loxone panel. - MVHR on the same wall, but all the way over to the right, ideally at a height that makes changing filters doable without a stepladder. Thanks Dan but in my current design, the MVHR is on the outside wall. The crowded pipe drawing is the old situation, my recent post shows the current thinking Edited July 11, 2023 by puntloos
