Pipe on soil?
Super_Paulie
3 minutes ago, TonyT said:
Clip the pipe, cable everything, laying on the ground is a bodge.
Good man. When you say cable everything, what do you mean exactly? I could all use round band instead of clips, need to see how much room I have to swing a hammer.
Sorry Meant pipes and cables all really designed to be clipped to a surface/supported at regular intervals depending on the diameter/material in question.
all round band is a good choice when a clip isn’t easy to fit
2 hours ago, Oz07 said:
Depends on invert level surely? If existing low enough then a trench out the ground with the correct amount of pea gravel under and around. It's what happens under a block and beam
Makes sense. But this is in my extension and it's a concrete subfloor, void then joists.
I've enough room to get my impact in so I'll clip to the underside, seems fair.
2 minutes ago, Dave Jones said:
when you say water pipe do you mean mains?
Should remain 750mm below ground then insulated where it comes up into the house.
our water board inspect and wouldn't entertain any above ground clipping.
Sorry, no not mains. That's happily buried in the garden 👍. It was domestic water lines I was on about, under my joists.
