bmj1 Posted June 6, 2023 Posted June 6, 2023 We will be dry lining our exterior walls with insulated plasterboard, to bring up u values. Can we wet plaster the interior ones, or is that madness and we should use plasterboard throughout ?
Big Jimbo Posted June 6, 2023 Posted June 6, 2023 I think wet plaster will cost you more, but may sound better when you give them a thump.
nod Posted June 6, 2023 Posted June 6, 2023 Nothing to stop you skim the ceilings and dry lined walls Then do the the wet plaster Use 100 mill fibre tape on board to solid wall
nod Posted June 6, 2023 Posted June 6, 2023 18 minutes ago, Mike said: FWIW, I'd choose wet plaster too. Cost wise there’s not a lot in it
Mr Punter Posted June 6, 2023 Posted June 6, 2023 I spent yesterday hacking off a thick layer of bonding plaster on a Victorian house. It had really sucked up a load of moisture. The previous owner had dabbed insulated P/B but one wall was part below ground, so that failed. PITA.
bmj1 Posted June 6, 2023 Author Posted June 6, 2023 50 minutes ago, Mr Punter said: I spent yesterday hacking off a thick layer of bonding plaster on a Victorian house. It had really sucked up a load of moisture. The previous owner had dabbed insulated P/B but one wall was part below ground, so that failed. PITA. Are you saying that as a good thing that it sucked up the moisture ?
Mr Punter Posted June 7, 2023 Posted June 7, 2023 11 hours ago, bmj1 said: Are you saying that as a good thing that it sucked up the moisture ? No, a disaster. Don't use bonding on any walls that are likely to be damp. The moisture wicks though the bonding and spreads out.
