Building regs drawings myself?
Sophiae
On 03/06/2023 at 19:00, TonyT said:
no I mean search for a property, so you drive past a house like the look of the work, find the drawing online and use that as a starting point for your drawing.
like below
http://planning.northamptonboroughcouncil.com/civica/Resource/Civica/Handler.ashx/doc/pagestream?DocNo=10971130&pdf=true&filename=Plans - M00521-100-01 Structural Plans %26 Details.pdf
Great idea. I didn’t know plans could have free access.  ill consider it. Thank you.
  • 1 month later...
Why not just do it on a building notice and make it up as you go along? No need for drawings if your builder is vaguely competent.
We're doing 16m2 rear extension, mono pitch, on a notice at the moment.
I suppose because I am a visual person and I don’t understand most of the work unless I can see a drawing or a video of it. It will be easier for me to write things down when I am able to go through the layers and details, rather than miss important details and then it would be my fault.
I managed to find a few really good resources online along with copyrighted drawings which I am able to use for guidance. Equally very fortune to have an experienced guide reviewing my work till my final submission.
1 hour ago, Sophiae said:
I would preferably something like this for a pitched roof.
Screenshot_2023-07-12-15-45-31-048_com.google.android_apps.docs-edit.thumb.jpg.d28eba58ab8a9f27f38b929f63bc315e.jpg
Much less wasteful of labour and  material and cheaper by my calcs too.
Better for airtightness and windtightness and heat protection also if done properly.
Edited by Iceverge
Fair enough… I’m a close my eyes and visualise it sort of person so I have no need for drawings and all that guff 🤣 my builder is a building notice kind of guy so we get on well.
This website below is what I used to do prepare my own Planning & Building Reg drawings for a 'wrap around' 2-storey rear extension /single storey side extension.
Along with lots of research online and it also helped me being a Mechanical Engineer able to use AutoCAD.....
The website below is also recommended by my local authority Building Control:-
Yes. One which we like is from a company called Building Regs 4 Plans.
The website is: www.buildingregs4plans.co.uk
Edited by MAB
