BS:845-1 and Approved Document A state cavity plus 125mm and then select the nearest standard length.
Search around though as I’ve seen 350mm cheaper than 325mm..!
1 hour ago, ETC said:
That NHBC guidance is incorrect as it does not include Note 3 from Table 5 of Approved Document A, which refers to cavities of over 175mm (of which this is) and a requirement for 125mm or 62.5mm embedment in each wall.
Ancon have an easier to read version here and the full version is here on Page 23.
