richo106 Posted May 21, 2023 Posted May 21, 2023 Hi I have just measured my first floor ceiling height (from bottom of ceiling joists to floorboards) It is around 2450 (give a take 5mm either way) I will be having a mixture of stud walls and dot/dab. I will be having a vcl at ceiling level, I wasn’t going to have a service void but now I have measured it is worth have a service void so that will bring it down slightly so I can use full length boards? Also is it best to install service void battens and plasterboard for the whole ceiling first before installing the studs for walls? Thanks in advance
nod Posted May 21, 2023 Posted May 21, 2023 I used to do work for a housing company that had us board the bedroom ceilings before the studs Great for us Electricians and plumbers hated it Saves time and money and a better job
richo106 Posted May 22, 2023 Author Posted May 22, 2023 11 hours ago, nod said: I used to do work for a housing company that had us board the bedroom ceilings before the studs Great for us Electricians and plumbers hated it Saves time and money and a better job I am the electrician and plumber so I'll just have to moan at myself Still undecided on the service void 1
TonyT Posted May 22, 2023 Posted May 22, 2023 Is there another floor above or a loft void to access plumbing and electrical?
richo106 Posted May 22, 2023 Author Posted May 22, 2023 1 hour ago, TonyT said: Is there another floor above or a loft void to access plumbing and electrical? loft void, plenty of access but i know it was mentioned to create a void so didn't have as many cables coming through the VCL What is the biggest gap I can leave at the bottom of a wall board that is dot and dabbed? If the floor to ceiling joist is 2450mm, if I just put a single plasterboard on the ceiling it will be 37.5mm at the bottom of the board.
jayc89 Posted May 22, 2023 Posted May 22, 2023 I have 2.5m high rooms upstairs, once the ceiling service void is in place it will leave me with approx 2460mm. We have 200mm skirts, so I plan on starting the PB 60mm above floor level and using full sheets.
TonyT Posted May 22, 2023 Posted May 22, 2023 52 minutes ago, jayc89 said: I have 2.5m high rooms upstairs, once the ceiling service void is in place it will leave me with approx 2460mm. We have 200mm skirts, so I plan on starting the PB 60mm above floor level and using full sheets. Will you have a double timber at the bottom? Otherwise your bottom edge of plasterboard won’t be supported?
