Archer Posted May 3, 2023 Posted May 3, 2023 (edited) Hi All, Embarking on a home retrofit and considering options. Our house is 1970s timber frame with 75mm mineral wool insulation in the (90mm) studs. We might be able to fit external wall insulation to the 1st floor which is cedar shingles but the ground floor has brick cladding and a cavity... So... Looking at options for IWI, will probably do it room by room rather than a big bang and I like the idea of Aerogel because it wouldn't need a huge amount of extra space to make a big improvement. The cost though is hideous. This is a long shot, but wondering whether anyone here managed to find an importer from China or elsewhere that makes this product more affordable? Edited May 3, 2023 by Archer
SteamyTea Posted May 3, 2023 Posted May 3, 2023 Our @DamonHD is the man to chat to. He did similar in his place. improving airtightness in a 70s place will make a huge difference.
RobLe Posted May 3, 2023 Posted May 3, 2023 (edited) What’s the lambda for the aerogel ? I don’t think the blanket stuff typically used is as magic as the solid spaceage (silly price) stuff ! And compare it with regular PUR, which I have seen as low as 0.018, though it’s mostly 0.022W/K/m. Consider VIP (vacuum insulation panels) perhaps? I think these are better, but tricky to use as they come in discrete sizes. I’m not sure why they’ve not taken off. Digikey have some, I think they get used in high end fridge freezers (ours has them). Eg this one for 1off cost £51, 600x600mm, 25mm thick, U=0.18W/m/degC. You’d need 100mm or a bit more of PUR to get that. Nb, I had to convert imperial R to metric U values, I think I got it right, pls check! I’ve not used the stuff mind. https://www.digikey.co.uk/en/products/detail/panasonic-industrial-devices-fbd/CNRZZB78400/9558502 Edited May 3, 2023 by RobLe Link
Temp Posted May 3, 2023 Posted May 3, 2023 (edited) 4 hours ago, Archer said: I like the idea of Aerogel because it wouldn't need a huge amount of extra space to make a big improvement. The cost though is hideous. Raw aerogel is good stuff but I don't think it's available and too fragile? The blanket version doesn't appear to be much better than rigid PIR... Google found.. https://thermtest.com/application/aerogel-thermal-conductivity-hfm Quote The aerogel blanket displayed a thermal conductivity reading of 0.024 W/mK at 20˚C. https://en.m.wikipedia.org/wiki/Polyisocyanurate#:~:text=PIR is typically produced as,on the perimeter%3Aarea ratio Quote PIR is typically produced as a foam and used as rigid thermal insulation. Its thermal conductivity has a typical value of 0.023 W/(m·K) So in this case its marginally worse not better. Note: Thermal conductivity is the a property of the material. Its like the U-value for a 1m thick block of the stuff. So to calculate a rough U value for any thickness T (in mm) you can multiply by 1000/T. So U value of 100mm thick would be 0.023 * 1000/100 = 0.23 W/m²K. That's the insulation alone not a whole wall. Edited May 3, 2023 by Temp
Archer Posted May 3, 2023 Author Posted May 3, 2023 4 hours ago, SteamyTea said: Our @DamonHD is the man to chat to. He did similar in his place. improving airtightness in a 70s place will make a huge difference. Cheers, hoping Damon responds with some words of wisdom. On airtightness, yes I heard that for detached houses (ie. with a relatively poor form factor) that airtightness starts to become more significant than insulation. It also feels like it will be harder to sort out though. We've got what looks like a pretty well installed and maintained polythene VCL between the plasterboard and the studs. The loft is well insulated but very drafty so planning to tackle that as as relatively easy win. Other than that though I worry that airtightness might be difficult to drastically improve. Ideas welcome though
Archer Posted May 3, 2023 Author Posted May 3, 2023 51 minutes ago, Temp said: Raw aerogel is good stuff but I don't think it's available and too fragile? The blanket version doesn't appear to be much better than rigid PIR... Proctor list the Lambda value for Spacetherm as 0.015 W/m2 so considerably better than PIR but you're right, it's actually not as good as I thought. The literature online seems to suggest that you can use about half the thickness of Aerogel for the same insulating performance in PIR - that value suggests that it's somewhat worse than that - and costs around £250/m2 (for c.15mm)
Archer Posted May 3, 2023 Author Posted May 3, 2023 (edited) 4 hours ago, RobLe said: Consider VIP (vacuum insulation panels) perhaps? I think these are better, but tricky to use as they come in discrete sizes. I know absolutely nothing about VIP's but my instinct is that they would be incredibly hard to DIY install and probably not suitable in walls where they could be accidentally punctured over time? PUR board with a conductivity as low as 0.018 sounds very interesting though, do you know who supplies this? Edited May 3, 2023 by Archer
RobLe Posted May 4, 2023 Posted May 4, 2023 Kingspan K108 lists sometimes as 0.018 or 0.019, eg: https://www.insulationhub.co.uk/product/kingspan-kooltherm-k108-100mm-cavity-board/
DamonHD Posted May 4, 2023 Posted May 4, 2023 11 hours ago, Archer said: Cheers, hoping Damon responds with some words of wisdom. On airtightness, yes I heard that for detached houses (ie. with a relatively poor form factor) that airtightness starts to become more significant than insulation. It also feels like it will be harder to sort out though. We've got what looks like a pretty well installed and maintained polythene VCL between the plasterboard and the studs. The loft is well insulated but very drafty so planning to tackle that as as relatively easy win. Other than that though I worry that airtightness might be difficult to drastically improve. Ideas welcome though Hi, Not sure that I have any of that wisdom stuff to dispense, and I am in the middle of preparing for a meeting, but here is some of my write-up which may be useful (follow the "See also" links in the sidebar): https://www.earth.org.uk/note-on-Spacetherm-aerogel-thermal-insulation.html Rgds Damon 1 1
ToughButterCup Posted May 4, 2023 Posted May 4, 2023 Saved for a good read later this evening. Thanks Damon. Ian
Archer Posted May 4, 2023 Author Posted May 4, 2023 This is really useful thanks @DamonHD. It's always worth asking a question on Buildhub. Awesome forum... The rabbit hole that I'm now exploring is whether spending money on PV to offset increased energy use will actually be more cost efficient than significant extra insulation. I'm sure others have been on this journey, will share any interesting findings.
JohnMo Posted May 4, 2023 Posted May 4, 2023 That's a quick rabbit hole to close - no PV generation in winter is pants. About 10 to 20% of summer performance. Spend on insulation 2 1
