I am not sure what your question is, buy my recommendation is choose one of the treatment plants that work with an air blower, and avoid the ones that have moving mechanical parts down in the smelly stuff.
By muck munchers I am guessing you mean a macerater and pump like Saniflo.
If so,ย  then yes, they are fine for feeding to the stp. In fact they have turned the contents to soup and treatment will be all the quicker.
22 minutes ago, everdecreasingcircle said:
I believe they are good bacteria that you flush down the loo every monthย  so to promote good bacteria?ย  I just wondered if anyone on here had used them. ๐Ÿ˜†
Do a sight search as there is quite a long thread on it. Can't remember who started it.
Google site search is usually better than the forum search facility.
4 hours ago, everdecreasingcircle said:
Hi
ย
I have read abit about these on here.ย  Are they suitable for a STP?ย  Does anyone recommend them?ย  Any advice on using them?ย  Thank you.
The answer might depend on what problem you are trying to solve?
ย
Personally I have used them for about 3 months (so starter ย dose plus 2 monthly doses) with the hope they would reduce the % solids in my STP and they donโ€™t appear to have made any difference. Note that the STP was and is working fine anyway - I just wanted to see if they would extend interval between pumping which they claim to be able to do. Maybe 3 months is not long enough and maybe if %solids is already high then they canโ€™t be expected to make inroads in that ย situation, so the jury is out atm.
Now that I know that you mean a packet of bacteria I can answer again.
ย
I have put in I think 3 STPs and had no negative feedback from the clients.
The manufacturers don't seem to insist on them either.
ย
A bag (or bottle) of it won't do any harm, especially at the start , to kick it off, because it won't get properly festering for a week or so.
But I don't think you need anything.
ย
ย
ย
ย
ย
ย
