everdecreasingcircle Posted April 19, 2023 Posted April 19, 2023 Hi I have read abit about these on here. Are they suitable for a STP? Does anyone recommend them? Any advice on using them? Thank you.
ProDave Posted April 19, 2023 Posted April 19, 2023 I am not sure what your question is, buy my recommendation is choose one of the treatment plants that work with an air blower, and avoid the ones that have moving mechanical parts down in the smelly stuff.
SteamyTea Posted April 19, 2023 Posted April 19, 2023 7 minutes ago, pocster said: Muck munchers ?? 🙄🙄🙄🙄🙄🙄 Muck, not rug.
saveasteading Posted April 19, 2023 Posted April 19, 2023 By muck munchers I am guessing you mean a macerater and pump like Saniflo. If so, then yes, they are fine for feeding to the stp. In fact they have turned the contents to soup and treatment will be all the quicker.
Pocster Posted April 19, 2023 Posted April 19, 2023 5 minutes ago, SteamyTea said: Muck, not rug. Beggars can’t be choosers 😉
SteamyTea Posted April 19, 2023 Posted April 19, 2023 8 minutes ago, pocster said: Beggars can’t be choosers 😉 1
everdecreasingcircle Posted April 19, 2023 Author Posted April 19, 2023 I believe they are good bacteria that you flush down the loo every month so to promote good bacteria? I just wondered if anyone on here had used them. 😆
SteamyTea Posted April 19, 2023 Posted April 19, 2023 22 minutes ago, everdecreasingcircle said: I believe they are good bacteria that you flush down the loo every month so to promote good bacteria? I just wondered if anyone on here had used them. 😆 Do a sight search as there is quite a long thread on it. Can't remember who started it. Google site search is usually better than the forum search facility.
Pocster Posted April 19, 2023 Posted April 19, 2023 (edited) Ummm Edited April 19, 2023 by pocster Ummmm
Crunchynut Posted April 19, 2023 Posted April 19, 2023 4 hours ago, everdecreasingcircle said: Hi I have read abit about these on here. Are they suitable for a STP? Does anyone recommend them? Any advice on using them? Thank you. The answer might depend on what problem you are trying to solve? Personally I have used them for about 3 months (so starter dose plus 2 monthly doses) with the hope they would reduce the % solids in my STP and they don’t appear to have made any difference. Note that the STP was and is working fine anyway - I just wanted to see if they would extend interval between pumping which they claim to be able to do. Maybe 3 months is not long enough and maybe if %solids is already high then they can’t be expected to make inroads in that situation, so the jury is out atm.
saveasteading Posted April 19, 2023 Posted April 19, 2023 Now that I know that you mean a packet of bacteria I can answer again. I have put in I think 3 STPs and had no negative feedback from the clients. The manufacturers don't seem to insist on them either. A bag (or bottle) of it won't do any harm, especially at the start , to kick it off, because it won't get properly festering for a week or so. But I don't think you need anything.
