MMcGill Posted April 12, 2023 Share Posted April 12, 2023 Has anyone come across this type of cooker vent and used it with MVHR? It would seem to be a good solution to retain an air tight house when not in use? https://luxairhoods.com/cooker-hood-Ducting-150mm/150mm-Cooker-Hood-Ducting-6%22/airtight-ducting-vent-kit Link to comment Share on other sites More sharing options...
joth Posted April 12, 2023 Share Posted April 12, 2023 (edited) Hmmm they say it is "blower door tested" but don't publish the result of the test. It works like so: "This simple yet effective airtight wall vent, is opened by the air pressure of the extractor system when turned on." I can't see how that doesn't open when doing the positive pressure blower door test. Most likely they expect it to be taped shut during house testing. Also, In an airtight house, where does it draw additional incoming air from in order to expell? Putting the MVHR on boost may help that, but in which case may as well rely on the MVHR to do the extract too, per JohnMo below 👇 Edited April 12, 2023 by joth Link to comment Share on other sites More sharing options...
JohnMo Posted April 12, 2023 Share Posted April 12, 2023 Just fit a recirculation kit to a standard cooker extractor, job done. Cooker hood used when frying only, but nearly always off. We have the room extract about 4m away from the hob, with a filter sock in it, just put MVHR on boost and it takes care of everything. Link to comment Share on other sites More sharing options...
Post and beam Posted April 12, 2023 Share Posted April 12, 2023 How much? That was meant to be an exclamation of shock not actually a question. Link to comment Share on other sites More sharing options...
Seeoda Posted May 17, 2023 Share Posted May 17, 2023 This question s a major issue that doesnt seem to be really being looked at properly. In some countries, all rental properties legally most have an externally vented hood. I dont know what the solution is. Link to comment Share on other sites More sharing options...
Conor Posted May 18, 2023 Share Posted May 18, 2023 It's not a major issue as a recirculating hood/hob does the job fine at removing particulates and odours. the MVHR will mop up any excess odours and moisture anyway. I came from a house where I installed my own designed externally mounted 900m3hr system, to a house with recirculating hob and MVHR. The latter is superior. Link to comment Share on other sites More sharing options...
Seeoda Posted May 18, 2023 Share Posted May 18, 2023 (edited) 1 hour ago, Conor said: It's not a major issue as a recirculating hood/hob does the job fine at removing particulates and odours. the MVHR will mop up any excess odours and moisture anyway. I came from a house where I installed my own designed externally mounted 900m3hr system, to a house with recirculating hob and MVHR. The latter is superior. It can be where the state requires you to install an external hood. I am in this position now and I feel like I am butchering my house. BTW what are you kitchen extract flow rates? 13 l/s? Edited May 18, 2023 by Seeoda Link to comment Share on other sites More sharing options...
Conor Posted May 18, 2023 Share Posted May 18, 2023 I set our kitchen at 30lps on boost. It's a big, open area though and I think that helps dilute any smells. 1 Link to comment Share on other sites More sharing options...
