Or use one of the LVT brands that have underlay built in - we chose the Malmo Rigid Comfort range as it comes in tile format as well as plank format.
  • 3 months later...
Hi all. Would like to follow up on this - I am building floor in my flat (LVT / Luxury vinyl with underfloor heating, self levelling compound on top of it):
  • Do I need underlay in this case? Or is it only required for uneven surfaces (which after the self levelling compound, should not be an issue?
  • What are the minimum parameters I need of the underlay - I have been advised that compressive of 400 kPa is a minimum to ensure longevity / sturdiness of floor
  • Is it a good idea to buy the LVT with integrated / attached underlay? There seem to be quite a few of these on the market - but the underlays attached are typically IXPE or similar - which (according to some) do not meet the required criteria (compressive strength and others)
Any advice welcome.
Thanks
Jan
I wouldn't bother.
We did both and the one without is much better. Less bubbles etc. I think this is mainly due to the thermal coupling of LVT and concrete with underlay.
