IanMcP Posted March 21, 2023 Share Posted March 21, 2023 ok, my wall make up is 100mm stud at 400 centres. Each wall has 18mm OSB on one side , 12.5 plasterboard both sides (obvs!) I need to sound insulate the internal walls. From what I can gather 75mm would be optimum to leave an air gap and not stuff 100mm in as that will only help transmit any noise, or at least help. There's so much guff on products to choose from - Rockwool RWA, Rockwool sound insulation, Knauf sound insulation, Isover, URSA acoustic roll how much does density have to play in selection ? also, it seems my using 400 centres limits off the shelf choice and I will have to cut 600mm down Real world feedback and examples please ? Link to comment Share on other sites More sharing options...
Mike Posted March 21, 2023 Share Posted March 21, 2023 As mentioned in a previous thread, the simplest solution is to look at manufacturers technical literature - they have built and tested real-world examples for you to choose from. Also, note that airborne sound and impact noise need separate consideration - most of the focus goes on the former. And know that, because decibels are logarithmic, a cut of 10db = a halving of noise, 5db = a useful reduction, 3db = just about noticeable. Link to comment Share on other sites More sharing options...
nod Posted March 21, 2023 Share Posted March 21, 2023 You will get far better soundproofing using MF studs with 25 mil acoustic insulation Timber sheets won’t help with soundproofing 600 centres are fine Saves cutting the rolls Link to comment Share on other sites More sharing options...
IanMcP Posted March 21, 2023 Author Share Posted March 21, 2023 1 minute ago, nod said: You will get far better soundproofing using MF studs with 25 mil acoustic insulation Timber sheets won’t help with soundproofing 600 centres are fine Saves cutting the rolls Walls already built. Link to comment Share on other sites More sharing options...
Dan F Posted March 22, 2023 Share Posted March 22, 2023 (edited) 2 hours ago, IanMcP said: 12.5 plasterboard both sides (obvs!) Two layers of acoustic PB is what is often recommended. resilient bars too if you want the best result. Have a look at the British Gypsum "White Book" for real build-ups with dB ratings. https://www.gyproc.ie/sites/default/files/Non-loadbearing timber stud.pdf Edited March 22, 2023 by Dan F Link to comment Share on other sites More sharing options...
SuperJohnG Posted March 22, 2023 Share Posted March 22, 2023 On walls between rooms and toilets O used sounbloc 15 mil on 90mm studs with 50 mil acoustic roll from superglass Link to comment Share on other sites More sharing options...
nod Posted March 22, 2023 Share Posted March 22, 2023 8 hours ago, IanMcP said: Walls already built. No problem If you have the room Resilient bar is cheap and quick and I would use 15 mil soundblock boards either side Link to comment Share on other sites More sharing options...
PNAmble Posted January 6, 2024 Share Posted January 6, 2024 If the timber frame internal walls are 100mm is it best to leave an air gap and fill with rock wool at 75mmm or no air gap ? where we need extra sound insulation (for example against plant roof wall) we’ll be double plaster boarding one side. Link to comment Share on other sites More sharing options...
Dan F Posted January 8, 2024 Share Posted January 8, 2024 (edited) On 06/01/2024 at 09:27, PNAmble said: If the timber frame internal walls are 100mm is it best to leave an air gap and fill with rock wool at 75mmm or no air gap ? Typically don't pack full. Our studs were 89mm and i think we used 50mm mineral wool. On 06/01/2024 at 09:27, PNAmble said: where we need extra sound insulation (for example against plant roof wall) we’ll be double plaster boarding one side. Consider using i) double soundbloc and ii) resilient bars (on one side at least) for best results. Edited January 8, 2024 by Dan F 1 Link to comment Share on other sites More sharing options...
