JohnBishop Posted March 11, 2023 Posted March 11, 2023 Hi All, I hope you are doing well. I have a front yard fence with short concrete posts. Should I get someone so pressure wash it or should I wire brush it then paint it or sand the surface with flex grinder? Flex grinder cleaning is what I saw on the Internet. Please advise Thank you Best regards
ToughButterCup Posted March 11, 2023 Posted March 11, 2023 The end-in-mind is ? Cleaning? Preserve rather than replace? Create a fungus garden? For each a different workflow .....
markc Posted March 11, 2023 Posted March 11, 2023 Pressure wash! The surface will be pitted so dirt gets deep into the surface, yes you could grind off with a diamond disk but the work and resulting finish would be terrible. 1
Iceverge Posted March 11, 2023 Posted March 11, 2023 2 hours ago, Dave Jones said: sodium hypochlorate +1. Spray or brush on a dilute solution. Be careful with your skin and eyes obviously. Doing it in slightly damp/misty weather seems to help it soak in I find. Quite often just a rince with a bucket and brush once the chemicals have worked will do the trick but a pressure washer will make it a simple job. 1
JohnBishop Posted March 12, 2023 Author Posted March 12, 2023 On 11/03/2023 at 10:02, ToughButterCup said: The end-in-mind is ? Cleaning? Preserve rather than replace? Create a fungus garden? For each a different workflow ..... yes, preserve because I am not ready to replace it, perhaps this time I would replace with long posts
JohnBishop Posted March 12, 2023 Author Posted March 12, 2023 (edited) On 11/03/2023 at 12:32, Dave Jones said: sodium hypochlorate do you mean just bleach? 22 hours ago, Iceverge said: +1. Spray or brush on a dilute solution. Be careful with your skin and eyes obviously. Doing it in slightly damp/misty weather seems to help it soak in I find. Quite often just a rince with a bucket and brush once the chemicals have worked will do the trick but a pressure washer will make it a simple job. what proportions 50/50? Should I look for a pressure washer or get someone to do it? Obviously I have to avoid crap pressure washers. I have no experience. Edited March 12, 2023 by JohnBishop
Dave Jones Posted March 12, 2023 Posted March 12, 2023 https://www.ebay.co.uk/itm/285121580537?hash=item4262920df9:g:gikAAOSww75j0VRp&amdata=enc%3AAQAHAAAA8Oo2VkeYjPSaqtN7JVb1u5YOlFDX3CiTLo14RM0%2BlMepZHo6JoiEafYIbL0N2M3L5Zaft9uxo%2FNgtcJ%2B9aJLoDtQ5A%2FHMdBe0NWKZeP4RqKy5bKRSXpYYyY15J8HqDVfa5GjdbV33tfBLExBh20%2FA2yhAm9limeVMSBUdKaWo9GPv1yBC09ai81kplq9Wlml1Kp%2FThCNNEoGmSgrQbbhG1ueoqstXGrCSNeB6yWyaKNVNdty8Q2c9FtFDuV50ClaLYVYYIEEQdnr6aiTQ68I6xlJ9zGu4rFS0G0brDHTbM3WzHd%2FlnxNa%2FufNPwXjSnaqg%3D%3D|tkp%3ABk9SR7Ljy-HaYQ 1
Iceverge Posted March 12, 2023 Posted March 12, 2023 1 hour ago, JohnBishop said: what proportions 50/50? Should I look for a pressure washer or get someone to do it? Obviously I have to avoid crap pressure washers. I have no experience. It's been a while but I seem to remember much more dilute that that. Safer to start weak 90:10 maybe and up the dosage from there. If it's just green algee a brush and a garden hose will shift it. Otherwise a cheap karcher or similar will get the job done. 1
