SteamyTea Posted February 20, 2023 Posted February 20, 2023 6 minutes ago, Adsibob said: these are 75cm It is the size of the feet that is important. I would hope that wardrobe manufacturers has thought about point loads on their products. It s not often we hear about them piercing a floor after all.
joe90 Posted February 20, 2023 Posted February 20, 2023 20 minutes ago, Adsibob said: with the adjustable legs on the pax wardrobes, we should be okay. Can the adjustable legs not be extended 16mm? I used to fit kitchens and did this often when the customer didn’t tile under the units 🤷♂️.
markocosic Posted March 13, 2023 Posted March 13, 2023 PAX feet are bloody useless anyway. You can't actually support a PAX on those feet without them shredding the bottom plate of the wardrobe. Set a strip of oly / OSB / chipboard down under each "side" of the PAX. Make sure those strips are dead level. (use packers) Screw 'em down. Slide the PAX directly on top of those. Also screw to the wall. I build the PAX without their backs so that your wall is ventilated. It's daft having a back to a wardrobe that's against a wall - especially an outside one that's cooler.
