Brickwork on new build not up to standard or am I being fussy
Apart from the obvious out of plumb to finish the brick joints that poor takes some effort. There is no way they used an actual pole jointer and ran it through them beds.  They look at best like they have used the round end of a shovel handle and brushed it while it was still wet as the brush marks are all over the mortar. Very very rough and I'm being kind.
Me personally would be looking them raked out. It's then up to you if you trust them to redo the joints or leave them raked out and get some one with an ounce of skill to do it for you or just have a raked out joint.
I would be going round each corner and long run with the level checking for plumb plus every single opening, windows and doors.
Apart from the out of plumb issue the brickwork has been pointed when it's too wet. Blues are difficult to keep on top of in winter. A good wash will make it look miles better though and then for not much money you can see what you have really got below all that mess. Where abouts in the country are you ?
1 hour ago, Mr Punter said:
Before you clad it, try some brick acid and jetwash.  It won't help with plumb but it can help the crappiest of jobs look acceptable.  I have seen oil applied to blues as a finish but not sure how long it lasts.
Thank you
we will give it a go
Thank you 😊
Much appreciated
I had blue engineering brick similar to those and found that a soft brass wire brush and soapy water was enough to clean up the mess on them. Mine were steps and when the screed in the house was laid the builders stood on the steps in their boots which made a horrible mess of them
