Scot5223 Posted February 1, 2023 Posted February 1, 2023 Hello Just joined today, moved into a 70s bungalow with dampness and a nosey neighbour. Hopefully find some ideas here. Sort Neighbour 1st though. I have a non boundary fence height question: Can it be taller or does the 2m rule apply, even if it splits my 8m wide garden down the middle, so 4m from any boundary, at least i can half it private. Thank you Scot
markc Posted February 1, 2023 Posted February 1, 2023 Hi and welcome, if it doesn’t affect traffic line of sight or restricts light into a neighbours window then I don’t know of any restriction … if you planted a hedge it could/would be above 2m in no time
Scot5223 Posted February 1, 2023 Author Posted February 1, 2023 Hi Mark Thank you, i thought of a hedge then considered it a more work, a friend mentioned leylandii, seems harsh. Was thinking of an 8 or 10ft fence would be ace. If not planning is an issue. Restricts light, good to know that rule too. Scot
Jenki Posted February 1, 2023 Posted February 1, 2023 11 minutes ago, Scot5223 said: a friend mentioned leylandii, seems harsh. I seem to remember that @Russell griffiths would have some constructive discussion points about leylandii.
larry Posted February 3, 2023 Posted February 3, 2023 On 01/02/2023 at 20:41, Scot5223 said: Hi Mark Thank you, i thought of a hedge then considered it a more work, a friend mentioned leylandii, seems harsh. Was thinking of an 8 or 10ft fence would be ace. If not planning is an issue. Restricts light, good to know that rule too. Scot https://www.planningportal.co.uk/permission/common-projects/fences-gates-and-garden-walls/planning-permission I read this differently, ie that a two metre limit would apply. But a hedge is fine. But I may be missing something. Knew a neighbour who had structural issues with Lleyandi, about ten metres from the property, so do watch that if you're seriously thinking it.
