herby Posted July 15, 2017 Posted July 15, 2017 (edited) Hi all, i'm new to the site & would appreciate some help I used interlocking concrete blocks (about the size of large breeze blocks) to self build a garage abroad years ago, I cant find any here, does anyone know of a supplier or producer in the UK ? Edited July 16, 2017 by herby
SteamyTea Posted July 16, 2017 Posted July 16, 2017 Can't help with the blocks, but any chance you can go and edit your post to make the texted larger. Looks like it has been super or sub scripted.
Gone West Posted July 16, 2017 Posted July 16, 2017 Hi Herby, welcome to the forum. Elite make Duo interlocking blocks but I think they are for temporary walls.
Declan52 Posted July 16, 2017 Posted July 16, 2017 https://www.legioblock.com/en/ Bit overkill for a garage. On the plus side of you paint them different bright colours it will be like a Lego build.
ProDave Posted July 16, 2017 Posted July 16, 2017 1 hour ago, Declan52 said: https://www.legioblock.com/en/ Bit overkill for a garage. On the plus side of you paint them different bright colours it will be like a Lego build. Look at the size of them, they are massive.
Declan52 Posted July 16, 2017 Posted July 16, 2017 53 minutes ago, ProDave said: Look at the size of them, they are massive. Hence the overkill!! Be cheaper and easier just to build a 9 inch wall.
herby Posted July 16, 2017 Author Posted July 16, 2017 Thanks for the responses, yep the legio blocks are HUGE, weight about half a ton. Does anyone know why the interlocking blocks aren't available here ?, they make DIY building projects almost fool proof.
