This is really cool. Think it was on the radio this morning but only caught a bit of the piece.
The claims of infra-red are what are frowned on. In the right circumstance they are as effective as anything else. I plan to have a ceiling or mirror panel in my bathroom - short term immediate heat.
It's fine that they're including IR panels in their experiments, but this stuck out:
Two competing heating systems are being tested inside: an electric-based system utilising infrared panels, some of which are disguised as ceiling coving, as well as a water-based system that uses heated skirting boards combined with an air source heat pump.
“As we put these really warm coats on to our homes, we don’t need as much energy to heat them,” says Novakovic. “So the big question we’re asking is, do we do it with heat pumps and hot water or with electricity?”
Aside from the fact that both ASHP and IR panels are "doing it with electricity", it seems ridiculous to bill this as the big question that justifies the £16M project...
Once again the main story about fabric first build quality has been lost in the debate around which bit of fancy tech we can add on top to heat an already low enery demand building.
  • Like 2
"Home is rated A, with running annual costs reduced to £11 thanks to the solar panels."
Er, that's got to be BS surely? Annual means getting through winter with weeks where there may be no solar. £11 of gas is 100kWh which won't meet the hot water demand alone.
Depends if you consider income due to PV export, or if using telsa tarriff for example.
But that's a very specific, small, amount. Why not just say zero if a few more sunny days would be all it would take to cancel all costs?
10 hours ago, Radian said:
got to be BS surely
I suppose it comes down to interpretations of what they mean my zero energy.
All the talk is about Net Zero, which I think is a reasonable aim at the moment.  In the future it may not be.
Main thing is that people are seriously working on it, rather than just talking about it.
I don't think that generation has to be on site to qualify, it just has to be dedicated generation.
I would like to see a row of old terraces that are converted to Net Zero, without combustion technology, that would be a real challenge.
I can guarantee neither of these was built to the developers standard quality regime as I’ve seen their Coppersmith and I’ve seen more airtight shopping bags …
Mirror panels tend not to be IR but are just radiant panel heaters stuck to the back of the mirror.
Surely any sort of radiant heat (that is, primarily transmitted via radiation rather than convection or conduction) is by definition an infra-red heater?
Not really.
Radiation happens at all frequencies, or wavelengths, if you prefer.
Some frequencies are absorbed better by some elements (bond strength, orbital paths/angles/distances).
Marketing loves it when people do not understand physics and think that a seemingly simple, and rational explanation, explains it all.
The biggest problem with Infrared heating is it cannot run at a high temperature, so needs a lot of area.
This causes the ratio between the emitter to the receiver to be large.
It makes no difference to the amount of energy needed to heat an object, but the power delivery, the W/m² is low.
Just heating the air in the building is probably best.
That way, we breath in warm air.
Yeah but anything hot will be emitting infra-red.
I'll probably end up just sticking up a bathroom bar heater anyway. Just checked the prices for the mirrors...
Fwiw I imagine a huge amount of the detail was lost in the newspaper editorial process. Our house went to The Times and the result that was published bore very little relationship to the facts I quoted to the reporter. For example:
Me: annual heat energy demand has been reduced by 90%
Press: household energy bill reduced by 90%
Etc
10 minutes ago, SteamyTea said:
A UV radiation source won't.
I'm definitely at the limit of my decades old A-level physics... but I don't think you can commonly buy UV heaters.
Not sure I want to turn my bathroom into a tanning parlour / skin cancer room.
49 minutes ago, SteamyTea said:
Sunbeds
I'd argue that is a UV emitter. You don't need heat to tan / sunburn.
Indeed, if you filled a sunbed with regular bar heating elements I think you'd grill the human.
Presumably ionising must take less energy than heat transfer.
Edited by George
