SteamyTea Posted January 22, 2023 Posted January 22, 2023 (edited) 2 minutes ago, Radian said: If only you could have powered the trip with the temperature gradient between the two ends. 🙃 Powered it with caffeine and cheese sandwiches. And 9 gallons of diesel, which is cheaper in Oxford than down here for a change. Edited January 22, 2023 by SteamyTea
Roger440 Posted January 22, 2023 Posted January 22, 2023 57 minutes ago, SteamyTea said: I moved all my possessions down in two trip in an old Corsa. That included my very long ladder, which I got rid of the other day. Im impressed. Ive always thought living "light" was a good idea. I just cant do it myself. Ive no idea what i would do all day?
jack Posted January 23, 2023 Posted January 23, 2023 10 hours ago, Roger440 said: Ive no idea what i would do all day? Perhaps sit on BuildHub typing "The correct unit is kWh" over and over? 3
SteamyTea Posted January 23, 2023 Posted January 23, 2023 1 hour ago, jack said: Perhaps sit on BuildHub typing "The correct unit is kWh" over and over? Save me the bother correcting the (expletive deleted)ing (expletive deleted)
Kelvin Posted January 23, 2023 Posted January 23, 2023 2 hours ago, jack said: Perhaps sit on BuildHub typing "The correct unit is kWh" over and over? Could easily be coded to automagically change it.
jack Posted January 23, 2023 Posted January 23, 2023 5 minutes ago, Kelvin said: Could easily be coded to automagically change it. Not really. The most common mistake is to use kW where kWh is intended, but kW is often used appropriately too. I don't think AI is at the stage where it could handle the distinction perfectly, but even if it were, the forum software isn't capable of doing this.
SteamyTea Posted January 23, 2023 Posted January 23, 2023 1 hour ago, jack said: Not really. The most common mistake is to use kW where kWh is intended, but kW is often used appropriately too. I don't think AI is at the stage where it could handle the distinction perfectly, but even if it were, the forum software isn't capable of doing this. And kw/h, Kwh, kwH, KWH, KW/h, KW/H. We should, as a species use the correct units of energy the joule, not Joule (unless referring to the man or at the beginning of a sentence). MJ is the more appropriate unit, 1 million joules, there are 3.6 MJ in a kWh, or 1 MJ is 0.2778 kWh when rounded to 4 decimal places, but in reality, 2 decimal place would do, so 0.28 kWh to the MJ. 1
Dillsue Posted January 23, 2023 Posted January 23, 2023 One from Scottish Power. Seems the pros cant even get the units right so there's no hope for the rest of us 1
