BadgerBadger Posted December 21, 2022 Posted December 21, 2022 I have a slight issue where part of my substructure coursing heights are slightly out. I can correct it by laying the first course on a 40mm mortar bed, is this too thick? I would prefer to correct it in the first course, as it's getting close to being visible above ground, so just wondering what my alternatives might be?
MikeGrahamT21 Posted December 21, 2022 Posted December 21, 2022 Id say 40mm is too much personally. How about some kind of detail before you start above DPC? Maybe slate? Terracotta? Not entirely sure what would be suitable from a compressive strength POV.
Mr Punter Posted December 21, 2022 Posted December 21, 2022 Slate is pretty good. For 40mm you may need 2 layers but probably 1 will work.
Canski Posted December 22, 2022 Posted December 22, 2022 Brick on edge = 112 mm normal brick course 75 mm there’s 37 mm just bed up the BOE 3 mm and you’re there or use a split block if it suits.
Radian Posted December 22, 2022 Posted December 22, 2022 Concrete coursing slips are 40mm if that helps?
